there is almost NO turbo lag whatsoever. 2k rpm's it starts taking off.Florida240sx wrote:You got boost always ready don't you?
thank ya. and yup I love the KA and it's torque...can't wait to start building the motor to see what it can do.S14tat wrote:wow that is actually very nice numbers given the conditions. the 2.4 liters definitly help make more then a SR even at the same boost levels.
Neat little comparison, and yup T25 spools FAST..almost NO turbo lag...but ya it won't pump out too high of #'s...def. good enough for me though:: orion :: wrote:I did ~202rwhp / 209rwtq form my old setup, at ~4.5psi.
Since the #s were so similar, I wanted to plot the charts over each other to see the differences.
My setup was T3/T04E, 57 trim / non-intercooled / Hacked MAF / Stock ECU...so the big differences are the turbo.
I did this maily to illustrate how 7psi from a small compressor like a T25 is the same airflow as ~4.5psi from a T04E compressor...
See below:
You can see the T25 makes more TQ down low (quicker spool)...but even non-intercooled, the T04E looks better up top (starting at 5000rpm).
This isn't a great comparison, as my graph had lots of smoothing applied, yours looks to have none...but it's cool to check out none-the-less.
- Brian
to be honest with you - I'd have no idea..the turbo came with no lines on it - and it's oil/air cooled (oil lines used from the previous turbo that was blown). I had other's install it - so if they plugged up anything I wouldn't know about it....sorry.iknowyoulike wrote:Quick question for you Mustangs_suck, I'm planning to run a similar set up, and was wondering what you did with the water lines of the T25 did you just eliminate it? if so did you plug it up or just left it open?
This is exactly the point orion was making. PSI does not equal HP. Airflow=HP. A large turbo can flow the same amount of air at say 4.5psi as a small turbo can at 7psi. Think of turbos like hoses. And think of air as water. A firehose obviously moves more water at a set psi than a garden hose. If this weren't true, then nobody woudl ever need to upgrade turbos.erollinc wrote:can we see pics of the setup please!? im about to run the exact setup... i would have thought 7 pounds would get into the 220s ... hows your AF?
NGK Copper plugs. NGK plug wires.iknowyoulike wrote:can you tell me the types of plugs and wires you used i'm toast by this basic set-up. to many options but it looks like yours probably came out best so far.
My setup (again, with a T04E compressor) did 224rwhp at ~6psi.erollinc wrote:... i would have thought 7 pounds would get into the 220s ... ?
Here's the pics:http://nissaninfiniticlub.net/...1.jpgh ... t/...9.jpgerollinc wrote:can we see pics of the setup please!? im about to run the exact setup... i would have thought 7 pounds would get into the 220s ... hows your AF?
oh then lol - yes I guess it got smoothed a tiny bit thennissanfanatic wrote:Nah, there had to be some smoothing. One with zero smoothing has freaking loops and stuff. Looks crazy...
Did you compression test properly? Throttle open?
Nice numbers. Glad to hear you got it tuned right now. How does it feel?lol Good luck with the car.
thank youeddiec wrote: 180 ft/lb @ 3200 rpm, - nice
True - might be able to get a bit more, but not much i don't think. Pretty much running the stock set up as a SR, and I put to the wheels about what the SR makes at the flywheel:: orion :: wrote:My setup (again, with a T04E compressor) did 224rwhp at ~6psi.
See the chart here.
So IMO...no way will a T25 get you much better numbers than his @ 7psi.
[/food for thought]
- Brian
you got it...that guy's a f'in prick.Structure240sx wrote:i think i know the guy who bought that from. i used to talk to him alot on AIM (mrtakagarage) something like that
defintily a nice street setup, shame you went through a few problems
so true. I learned my lesson...too bad it took so much money to do it, but whatever....he'll get his in the end...karma works in mysterious ways.Structure240sx wrote:yea, i hear ya
shows that you should never buy a car without seeing it and drving it in person. like buying a pair of shoes with trying them on
rofl, at times I'd love to hop a plane to Flordia and knock on his door - but meh, not worth my time.IWannaS15 wrote:Funny, my baseball bat's name is Karma...
yeah I know...I'd love to release some stress on his face..but *sigh* wouldn't get me anywhere in paying my car off....it'd just land me in jail or some ****.Structure240sx wrote:almost is worth your time after all this, i think he was telling me he was keeping the silvia front end coupe with an sr in it, hmmm
sorry bad thoughts, i;ve been trapped inside most of the day, wish i had a street bike right now
