Dyno results
Mustangs_Suck
somthin240 wrote:Hmm, I live in Florida. I could "visit" him! (edit:i don't exist)
lol I'd pay you for your time if you got his assbeating on video. His name is legally "Christopher" but he calls himself "jap" to make himself sound more JDM tyte yo.... You have no idea how much he's pissed me off
Mustangs_Suck
nissanfanatic wrote:haha, if structure comes down here, all of us will pay him a visit for you.lol j/k
lol **** if it'd be a group thing, I'd hop my *** on a plane asap!
Mustangs_Suck
looks like he's trying to sell another car:zerothread?id=116330
hope someone doesn't get taken for the ride I have from him.
MarkEmark
Car: fully-built '95 240sx KA-T
Mustangs_Suck: You would have made considerable more power had your compression been up to spec...140 is not very good, neither is 150...not when it's supposed to be at ~175-180 psi...I'd say how much power you made is pretty impressive given the small turbo and the handicap of lack of compression...
Mustangs_Suck
MarkEmark wrote:Mustangs_Suck: You would have made considerable more power had your compression been up to spec...140 is not very good, neither is 150...not when it's supposed to be at ~175-180 psi...I'd say how much power you made is pretty impressive given the small turbo and the handicap of lack of compression...
yeah i've searched around and found they are kinda low numbers, but *shrug* nothing bad...there's plenty of people running around that compression or even a bit lower, and they are doing fine. It'll last me for awhile I'm sure...but a new stronger head and pistons + rods are on the list of things I should replace in the near future.
Jookmasta
congrats on the numbers. its good to finally see sumone put the t25 to the test on the KA. i guess my goal at the dyno will be to beat ur numbers but at least i know where i should b at or around. (playing the conservative role). i like ur spool tho...............
AN89HATCH
so will 10 lbs from a t25, and 10 lbs from a t3/t4 be equal in the amount of stress placed on the motor?
veilside180sx
No because the t3/t4 will still push more air into the cylinders. Although you also have to bring into the equation the amount of hot air coming in due to the smaller turbine. At 10 lbs i don't think either would hurt it much. The T25 shouldn't start to run out of breath until about 14 lbs.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
veilside180sx wrote:The T25 shouldn't start to run out of breath until about 14 lbs.
Ona 2.0 liter SR...yes, 14psi is about the limit.
But on a motor that's 20% bigger, I'll bet it won't hold 12psi to redline.
Just FYI...
- Brian
Mustangs_Suck
Jookmasta wrote:congrats on the numbers. its good to finally see sumone put the t25 to the test on the KA. i guess my goal at the dyno will be to beat ur numbers but at least i know where i should b at or around. (playing the conservative role). i like ur spool tho...............
thank ya. My numbers could of been higher, my compression is a bit low as ppl have said...and I still have a few quirks to still work out - but *shrug* I'm satisfied with it for now.
Good luck with your build - I know 200rwhp and 205rwtq isn't much, but believe me, the car PULLS.
Nismo_Freak
Car: 89 Nissan 240SX
Mustangs_Suck wrote:True - might be able to get a bit more, but not much i don't think. Pretty much running the stock set up as a SR, and I put to the wheels about what the SR makes at the flywheel
You would theoretically put down the same power at the wheels in an SR at 9 PSI
veilside180sx
True, but I was tired and rattling stuff off.=) T25 barely hold redline at 10 psi on a KA. hehe.
Mustangs_Suck
veilside180sx wrote:Ona 2.0 liter SR...yes, 14psi is about the limit.
right. I'll most likely upgrade to a T28 sometime soon. I know the T25 is pretty limited, but it's definitley good enough for a budget turbo set up.
