You also have to compound any adjustment of the distributer. If you have it set to the middle or retarded then yes, it will be choppy.klattr1 wrote:ive had my car and friends KA's off just one tooth at the distributor and it would barely idle. i would start it up and then it would die immediately die.
you can put the motor at TDC and then orient the distributor any way you fee like. it doesnt just go in or orient one way.WDRacing wrote:Not really, the CAS is idiot proof. It only goes in one way do to the exhaust cam dowel pin chingus. However, aligning the cams is a *****.
how are you gonna adjust for it when the distributor is off a tooth? ive had that thing advanced, retarded and in the middle when it was off a tooth and the dang car wouldnt start.where do you think half of the "i cant start my car or it doesnt idle or fire up right" type of threads come from? people get off one tooth and it just wont work. it might start up for 10-15 sec but on any throttle input, it will die.Nismo_Freak wrote:
Ahhh true true... forgot about the difference in them.WDRacing wrote:Not really, the CAS is idiot proof. It only goes in one way do to the exhaust cam dowel pin chingus. However, aligning the cams is a *****.
There is no CAS on the KA is there?? I was referring to the RB series when I typed that prior post. Meaning you can't install the CAS wrong like you can the a distributor, only adjust the cams wrong.klattr1 wrote:you can put the motor at TDC and then orient the distributor any way you fee like. it doesnt just go in or orient one way.
