Edub1 wrote:Isn't "trap speed" simply the speed you are going when you cross the finish line?
Anyway, cheeze is right. A high speed + a slow run means that you have a car that accelerated very quickly once it was going, but didn't come out of the hole well. Otherwise you would have reached a high speed in less time but not increased that top speed by much because that is so hard to do.
In other words, you were able to hit the wall, now you just need the hole shot so you can hit it sooner.
From my expirience as well as others in my local car club, trap speeds always go down when you hook well...
Once again, ET doesn't really matter to me. When I buy larger rims/tires, that is so I can drive the curves better. The most I'll ever go for tires is Kuhmo MXs. I'll probably never own a set of drag radials..
