check againDReed86 wrote:Come on Surman!!!!!
I think Ive checked this thread 17 times since yesterday!!!!!
Im dying to know
Please post
yo f*** u troll all u do is hate on everyone always on the forums .... whats the point of ur comment i think everyone knows what i meant.... u get a kick out of hating i know it makes u feel better about urselftoxik wrote:mike its stillen not stillin or stilling lmao
well the dyno its only activated and starts reading when im an 3 gear or like the other run 4th gear at that point i basically floor it to bring the rpm up to 6000+ rpm look at the chart and max torque.. u can see in the first video the run... btw rev limiter didn't work...BigDankCloud wrote:There is no way I believe that you are running 218 hp. Just from listening to the video it didnt sound like you made it all the way through the torque range before it changed "gear" on you anyway.
i agree this sounds retarted i may do some performance crap next n i got a 6mt so i can dyno yeah!!!!!!surmanm wrote:
what do u mean i didnt make it thru the torque range ????
honestly i dont know whats going on but id like to get to the bottom of this and figure out how nissan got the numbers of 270 then
hold up isnt whp different from hp the results i posted are HP look at the chart.. isnt stock 3.5 270 hp ur telling me i went down in hp after the mods ??alphapig wrote:How is 218WHP hard to believe?
Sounds accurate to me
+1bunda4th wrote:The way Nissan Dyno the car was most likely with a 6mt and technically they probably have a system to run the engine with out the car to see what it is producing at the crank and not the wheel.
Even going into manual mode in the CVT you are still using unlimited gear. It will not become a manual to give 1:1 ratio. When you go into manual mode you are only getting to control some things but you aren't really controlling the gears like if it was a 6mt.
Hope that make sense. Basically if you miss a gear or go to slow in manual mode you aren't hurting anything since it will shift on its own unlike a 6mt you can stay in red line with any gear and if you go to slow on a certain gear you will stall. CVT doesn't do that.
I might be wrong, but I thought that the HP numbers provided by manufacturers are measured at the crank. That is, the engine is run outside of the car in a test environment.surmanm wrote:
thanks for the clarification guys ...check the dyno sheet i posted all the pulls on the first page max power 212.69 max torque 209.96max power 216.57 max torque 214.75max power 218.04 max torque 247.12adidas2go wrote:
+1
Exactly right.
Nissan got their number because the VQ35DE in the G35 and 350z made 270hp. That's it. They don't dyno cars they put the same engine in. In fact, go check out the FX35, the number are the same, based specifically on the engine. That's it.
I'm curious to see the other 2 dyno pulls, I bet they aren't close to each other. No matter what you do for the CVT, if you put it in "M4" or not, the car will ALWAYS pull the most power from the lowest gear ratio is can. The best thing you can use to dyno a car with a transmission like this, is a G-Tech. Something that measures inertia vs weight. Don't trust a dyno and these CVT's. Been there, done that.
That's what I thought, thought I was a tripper for a while there.BigDankCloud wrote:
The manufacturer (Nissan) quotes 270 hp produced by the motor, at the crank.
WHP is what gets put down by the wheels, which is less due to the loss of energy in parts (from the transmission all the way to the wheel).
i would like to get enlightened as well....alphapig wrote:Lots of parasitic loss is expected, especially from the CVT transmission.
Am I off? Can someone enlighten me please?
yeah i understand that but im not pulling the results out of my butt there ur proof.. and the results are consistent numbers are more or less the same so 218 ???? come onBigDankCloud wrote:
Basically, without your mods (meaning if your car was stock), you show that you are losing about 20% of power in the drive-train. That isn't so hard to believe, but since you have both a y-pipe and the bully dog tuner which at least one of those (at least on the racingline website, which I believe) has been proven to be a hp producer to the wheels I don't believe these results.
yeah tell me abut it bro lol i was shocked.. maybe its bottle necking somewhere its alot of loss i deff wanna track the car now...blackteam02 wrote: 218Max HP!?!im sorry Surman, id be crushed if it were me..so all this talk of the "cvt" robbing the vq35de of hp, does this mean 6mt owners like myself should get a little more HP??
