Dumb ka24e question
ericevans14
Is the oil pump/distributor drive gear on the crank on the ka24e supposed to be flush with the lower timing gear if so then what drives the oil throw ring?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Yes it should be flush. Everything will be positioned when you torque the crank pulley down anyhow. Just make sure the oil thrower lines up with the crank keyway.
ericevans14
Ok the only problem with that is when everything is flush there is no keyway to hold the oil thrower it just spins how it wants too
Rev_D21
ericevans14
K see i remembered about a half inch space between the drive gear and the timing gear that allowed the oil slinger to be on a key way so thats the way i set it and timed it to that until it slid forward while i was driving and i could never set the timing right again so i had to tare the motor back down again
ericevans14
This is in a 90 model hardbody and what pics ive seen of the 240s the keys on the crank are alot longer
ericevans14
Nevermind i am a complete moron do you have any ideas on why my timing was suddenly so far off?
Rev_D21
Did you set the engine to TDC and mark your distributor? Did you line up the colored chain links to the marks on the sprockets?
ericevans14
Yes it was running perfect for a short time after chain replacment
Rev_D21
Then it stopped running? or it runs like crap now?
