Dante's s13 Coupe Build | Updated: 3/27 | NO56k
BigDAT
at last, my car is running it should be!
lemme break it down:
so somtimes while I was driving, the car would start only hitting on 3 cylinders, somtimes it would ix itself, other times it would not..
so I checked the plug wires, plugs, and distributor, and it was all just fine, then I took out the fuel rail, and switched the # 3&4 injectors (the problem cylinder was #4) and the problem started on the 3rd cylinder. so BAM, needed new injector.
ace came through in just seconds, car is now running like a champ, better then it had been.
Next thing to do is get a fuel filter..
BigDAT
lots of problems, replaced an injector since I was running on 1 cylinder, weak spark, blah blah blah
full details here:
car-not-starting-weak-spark-long-story-t528230.html
but noone seems to care enough to help..
so, after a bunch of crap, I belive it is my CAS, I have no tach signal when I am cranking it over, we disassembled the distributor and found OIL! yay, sept it ruined the CAS, we are off to pick n pull in the morning to get a new distributor, also my ECU was throwing 11 and 14, I believe it was only throwing 14 (knock sensor) because the cylinders were full of gas, but 11 is the CAS so thats good news.
also I replaced my fuel filter with a z32 filter:
BigDAT
look what I bought for $30:
6
unfortunatly, there was no distributors that would work, all the 240's were gone and the altimas and sentras are different..
still looking for a distributor, don't need the cap and rotor though
ridge
Car: 2002 GGP IS300 5 speed
Awesome build man. Is that taillight cracked? Can't wait for your wheels to get in so we can see them on!
BigDAT
Yes, hude hole in it, however with some love:
I havnt been updating this topic on this forum, because noone really has much feedback for me, I update the one of norcaldrift a lot more.
http://norcaldrift.org/index.php?showtopic=8947
