biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Fri May 14, 2004 10:57 am
Stock one? :P
FYI, the dropping resistor is 6 ohms, and the pinout should be in the FSM..
edit: this pinout info I gave here is wrong, look to my post below for corrected information, or check the FSM. Leaving post incorrect rather than fixing it so as not to break thread continuity
basicly:
(looking towards harness, made-up pin names, harness snap-in clip thingy on top)1     2     36     5     4
between 1 and 6, 2 and 6, 3 and 6, 4 and 6 should all be 6 ohms resistance. nothing on 5, its not really there.
of course you need beefy resistors that can resist the heat, cold, and power requirements..
