DrifterXRPS13 wrote:i got that bearing from carquest for 135 plus a chiltons manual for 20 bucks. haven't gotten a chance to install it yet but at least i got it. one more quick question, does anyone know how much the bracket that holds the center bearing costs?...i lied, another question, sorry, the aluminum driveshaft that everyone is talking about on this thread, someone said that the only negative aspect is the vibration, he also mentioned that that's what the center bearing is for, to stop the vibration, if that's true then wouldn't their be negative effects of the driveshaft just wobbling and possibly hitting against the bottom of the car?
apparently, the one that I linked can accept the carrier bushing (center support bearing, whatever) to lessen the vibration. it does offer a significant weight reduction, and looks like a good investment.
But after comparing the aluminum shaft to the stock shaft, I wonder why nissan included the U joint in the center. I could understand for installation, but the input shaft already has a U joint, allowing for it to properly be inserted while the shaft can lay at an angle and not be clunking around on the diff.
