DrifterXRPS13 »
https://forums.nicoclub.com/drifterxrps13-u10091.html
Mon Jun 21, 2004 7:46 am
i wish i had an inch of freeplay, mine was worse but that's awesome that you found it for $67, mine was 140ish from carquest...ripoff...well it took about 2-3 hoursfrom start to finish, realistically it should take only 30 minutes or so if you have all the correct tools and what not. You need a lot of WD-40 and soak the nuts and bolts and all that good stuff. it's not very difficult but you'll want a second person helping you out. i held the car up with two jacks right in front of the rear tires and i had a hydraulic jack holding up the rear of the car at the diff. You're gonna have to mark the location of the driveshaft to where it bolts up to the diff and the transmission, take off the bolts that are connected to the diff and unbolt the center support that holds the bearing and the middle of the driveshaft, make sure you have a friend helping you with this because it is pretty heavy. You can slide it out of the transmission with a little force and then proceed to disconnect the two pieces from each other and then this parts the most time consuming...you can either sit there trying to find some sort of socket or tool that will fit the nut that is right before the bearing or you could do the easy thing and take it to sears and have them take it off and put the new bearing in and stake the nut...it was free for me because my brother works there, even with the air tools it took a good 10 minutes to do, that sounds like a lot but if you have the right tools, a manual, and a friend, it should take only 30 minutes to an hour depending on how rusted the bolts are and what not. One more thing your friend will also come in handy for putting the transmission in and out of gear to twist the driveshaft to unbolt everything, that way you don't have to get out from under the car and back under every 30 seconds. sorry for the lengthy response but when i asked how to fixed it i just get some simple response but i gave ya the whole thang. if ya need any more info, let me know
