Driveshaft Q's
captainfalco
Car: S14,MX83
I've got 3 different driveshaft sets and I need to know if any combonations of these will work for my new setup (manual S14 w/abs).
1. S14 auto, no abs2. S14 manual, no abs3. S14 auto, with abs
I've done the 5-speed swap with my old S14 which is now wrecked, and I am now working on swapping everything over to my new auto S14 with abs. I've searched and haven't found exactly what I need to know.
I am just trying to see if I can get out of this without buying any more parts. If I do need to buy anything, it will probably be the 1-piece from shaftmasters. Thanks in advance
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Use the rear portion from an ABS, and the front portion from a manual. The rear sections from auto/manual are the same, they change abs/non abs. The front sections are same abs/non abs, but differant auto/manual. You get my drift?
captainfalco
Car: S14,MX83
A-ha! I knew one of the combos would work. Thank you much.
