drift brake pads
slikklogic
Car: 99 honda civic 1.8T!
95 240sx base/se
quick question. i have a s14 with stock brakes. which pads should i be running to lock the ebrake good for drifting? i adjusted the cable already and still not locking.. ive heard project mu bforce pads r best but oem nissans work good too.jus looking for some efficient setups
alms24sebring
'04 Nissan Sentra SER SpecV
Umm I would think that as long as they are not $20 pads, they're warm, and you are pushing the clutch while pulling the brake, there shouldn't ne a problem. Just keep it to the track. Empty parking lots are also exceptable.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Project Mu D1 Spec pads... However, they're not recommended for street use. Hawk carbon pads work great as well. Another thing you might want to try is get new ebrake cables. Old ones are probably stretched pretty bad.
slikklogic
95 240sx base/se
yea im stepn on the clutch wen i pull it.but they do nothing..im useing the car for daily so i dnt want the pads that r gonna wear fast... i heard hawks dnt work until there hot tho
costa_rican13
Car: 1993 s13 coupe
i say try those EBC red,yellow, or green pads.
ILoveMyRHS13
slikklogic wrote:i heard hawks dnt work until there hot tho
A nice little brake stand is all it takes to get rear pads warmed up.
slikklogic
95 240sx base/se
yea i mean i have hawks on my civic and there great but i kinda want something that i can just go into a parking lot n jus grab n slide ..with no warm up..i get oem at a discount.nobody knows if they grab good? some searches said they did but not much detail into it..i havent heard too much good from ebc tho.in terms of quality
bersh240
pull harder
White Comet
Car: fc, s13 and mazda6, Sierra
slikklogic wrote:i havent heard too much good from ebc tho.in terms of quality
do a little searching for reviews on them, theres plenty of good review out there on them. on my fc i have endless pads and it was awesome with them
slikklogic
95 240sx base/se
bersh240 wrote:pull harder
lol trust me i clutchd and pulled with a grand might and it jus slows down alil..i dnt get it
rsmithdrift
Car: 1993 240sx fastback se.
You need to readjust your cable then... or your is stretching very badly... your pads are not the issue unless they are worn metal to metal. I could lock mine even when they were down to metal on metal. My e-brake never quit having lockability.
cheezy240
Car: 1990 RB20 Hatch
Well i got Stock oem pads on mine and they work great. You will prob have to tighten the 10 mil nut on your handbreak but dont go crazy if you tighten it to much you will rub in the rear. I tightened mine and I can pull it up and the rear end whips right out just tighten the nut yo!
slikklogic
95 240sx base/se
lmao.^^ mayb they are stretching.ima go price some at work 2mrw(dealer).pads got meat but jus not the slighest sqeak.i adjusted it 3 times to oem spec.its very tight
alms24sebring
Make sure the calipers are squeezing too as if 1 is locked up or something. Have someone pull the brake and see how easily they move back and forth
I have hawk pads front and rear on my 240. Its true that they need to be warm to be good, but after 2 or 3 moderate stops, they grab pretty good for street pads.. and they are lasting very long for me.
Dittoz7
Car: 1997 2f0WtY SE!
Clutch kick!
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
That isn't one of the six acceptable initiation techniques as detailed by the Drift King... :nono:
ILoveMyRHS13
Dittoz7 wrote:Clutch kick!
Unless you're entering at high speed and/or have plenty of power, you have no need for ebrake.
GmFwd
Car: 1994 Beretta sleeper
The cheaper the rear pads the better. s*** pads have great initial bite but fade super quick. Thats exactly what you want for ebrakes. While all the hawk and Project mu pads will work decent, you will find that 18 dollar autozone pads work best. Scuff the rotors and your good
I have unknown pads on my car and can hardly lock the tires in a straight line. However, when Im drifting a little flick before you yank it and it drifts fine.
But like others said, you can usually get around using the ebrake. Clutch kicking to initiate or foot braking to scrub speed works good too. Everyone has a different style.
costa_rican13
Car: 1993 s13 coupe
clutch kick and shift locking work great :) or you could turn in, then counter turn, pull the ebrake, then "power over", as bow wow says in tokyo drift!
slikklogic
95 240sx base/se
SX APPEAL wrote:That isn't one of the six acceptable initiation techniques as detailed by the Drift King... :nono:
hahahahaha... i do clutch kick. but some times i am traveling to fast. id like a working eb anyway.ima check calipers too..i did scuff the pads already.stops better.no eb still
terry_240sx
Car: '93 240sx hatch
clutch kick ftw! haha
rsmithdrift
only use the e-brake to ELONGATE a drift or to scrub speed during a drift by braking w/o shortening your turning arc. When your already drifting the ebrake is super easy to lock. Its near impossible to lock any cable e-brake going in a straight line in full grip. if you have to use it to intiate use it at turn in with a hard flick of the steering and it'll lock easily. but it's hard to control an e-brake intiation from their on because the transition back into throttle is very tricky and the whole thing becomes unpredictable. Unpredictability while drifting = crash. So I avoid e-brake initiation at all costs.
slikklogic
95 240sx base/se
good tip.thanx.. but seems thats there only a total of 4 ebrake cables left and then they are no longer made.and the inital cable is already stoped production..thats coming from the dealer were i work.nj so were is everyone spose to find eb cables now? lol
slikklogic
95 240sx base/se
also pls keep in mind my s13 ppl.i have a s14 with no drum ebrakes..i know s13s easly have good eb drifts but somthing wit this design sucks
DanThaMan
Car: 1993 240sx
I don't really know what you were trying to say, but neither s13 or s14 use the drum style parking brake...
slikklogic
95 240sx base/se
i thought s13 has a drum eb?
GmFwd
It uses the same caliper, same setup.
Im hoping you just got mixxed up with the z32 rear brakes
DanThaMan
Car: 1993 240sx
Any time your rear caliper has two pistons(one on each side of the rotor) It will almost always use the drum style eb, If you only have one piston back there, the eb is usually incorporated into the caliper.
slikklogic
95 240sx base/se
ooo ok wen i searched this topic .they made it sound lyk s13's have drum parking brakes inside of the rotor.idk cuz i nvr had one or worked on one ..
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
Yo guys how do you replace the cables in an s13? Is there a write up somewhere?
