scuba_sean wrote:is there any advantage in doubble clutching?
scuba_sean wrote:ok, i only had one chance after i got my 240 to go to the track before it shut down for the winter, so ive done 3 runs, and i wanna kill when i go back. can anyone give me any tips? i think i prettymuch know what im doin, i think. im launching at about 3500rpm (limited slip diff), and im gettin pretty good reaction times (.5-.6). I got 17.4, but i later fond out i had 3 leaky injectors. also, is there any advantage in doubble clutching? it seems like more little things that could screw up goin down the track.
Lepchitz1 wrote:double clutching is more for down shifting...or saving your synchros. A good tip is to "Go on yellow", which means go on the last yellow. I got like an average .4 reaction time doin this. You want to launch at the beginning of your peak torque range, Depeinding on the temperature of the ground/tires is you will be able to judge on what to rev it to. Hope I helped
IvanS13 wrote:Dont wanna sound like an ***... but, dont believe everythin you hear in Fast and Furious.
C-Kwik wrote:Your transmission should have syncros. Double clutching takes longer. You have no need to do it.
scuba_sean wrote:why dont you 2 pull your heads out of your asses, and realize that there are people talking about the import world outside the sellout wold of the fatf.
IvanS13 wrote:I said I dont want to sound like an ***... sorry. Scuba, no offence taken. Double clutching is a technique used to match revs on a down shift, not of upshifting.
Siddhartha wrote:ok, double-clutching is used for rev-matching sometimes. Clutch in, neutral, clutch out, rev to match gear, clutch in, shift into gear, clutch out. Like, I'm shifting from 3rd to 2nd in a turn, on the edge of my tires lateral adhesion and don't want the car to jerk when I shift or I will lose grip and slide. Clutch goes in, I shift into neutral, clutch comes out. I rev the engine up enough to match where it would be at the car's speed in second gear. Clutch goes in, I shift into second, clutch comes out. Car won't jump b/c engine speed is acceptable for the given gear and car speed. Double clutching on an upshift is pointless, as whenever you up shift the engine speed decreases and you stop accelerating during the shift. It DOES help synchos, but only if they are already going bad. The main reason it is done, though, is to prevent the car from jumping in the twisties when on the limits of adhesion.
Don't do it in a drag race.
AznRide wrote:Um, that's POWERSHIFTING, not DOUBLECLUTCHING dude.
Anyways, doubleclutching is that when you are at around...let's say 5000RPM, with the foot on the gas, step on the clutch and release the clutch when you are at redline. If you car is powerful enough, you should get a *little* jump from the competition. You really need to know your car strength to do this. Takes times to try it for best results. Like my last post, I saved .25 of second, doubleclutching twice.
AznRide wrote:Anyways, double clutching is really bad on your transmission so don't do it if you have a bad transmission already. But if you are desparate and need to go a lil faster when you are bracket racing, feel free to try it out. If you are ahead of your opponent, just drive normal, and don't let him pass.
I've won every first place trophy (except for one 2nd place, I redlighted by .02 of a sec) so don't tell me that I'm dumb. Trophies in 1 year are 3 (17 secs class - stock motor, 16 sec class stock B16, and 15 Bolt-ons sec class). I never got to really test out my last one because it was a hot day and last season day, so everyone was there, never got to try, but ran my best 13.5 (with 75 shot nitrous, empty interior) first try, then I quit racing that day due to the rediculous temperature. Anyways, enough of me, what about you all?
