lilskyline240 wrote:im going to be using lowlifekustomz monunts and was seeing that i need to use the stock downpipe. This meaning a r33 or r32 downpipe? or S13 sr20 downpipe? Will a r33/r32 downpipe bolt up to my catback?
stock downpipe as in the rb's downpipe. i would think you will be wanting to run a larger diameter downpipe, if so, a custome one is in order.
lilskyline240 wrote:id be hesitent to order a driveshaft from a company that doesnt offer mounts. Every companies mounts put the engine in a different location which could cause the driveshaft not to fit if it isnt bought from the same person that makes the mounts
just my .02
i don't know what the problem is. think about this; if all the mount put the shifter in the center of the console, why would it make a difference who make the driveshaft, the length can't be much different where tollerance is an issue. if it was welded and ballanced properly i wouldn't worry much about it.
