Door Sill Clear Vinyl Project
Is $120 a good price to have 3M clear bra installed on my door sills?
Poll ended at Mon Feb 04, 2013 11:29 am
Yes
0
No votes
No
0
No votes
Total votes: 0
followingnfront
Car: 2017 Maxima S
So after reading the thread (which I can't find right now) about the door sill paint issues, I decided that I want to do something about it... I went to a local auto accessory shop today to find out about getting some clear bra installed on all 4 door sills... They said they have a "3M guy" who is very good and does all their clear bra stuff, and it would cost me $120 to get the sills done... I am not sure how clear bra prices go, but I figured it wasn't out of reach so I made an appointment for Monday and they said it should take 3-4 hours...
My car only has 900 miles and I figure its better to get it done as soon as possible...
So how does that price sound?
They also quoted me $60 to tint my front 2 windows to match the rears.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ImStricken is the resident expert on this sort of thing. I think he's taken today off. ;) I suspect he may be able to give you pointers to DIY and save $$$.
followingnfront
Car: 2017 Maxima S
Hopefully! Cause that would be awesome.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
Hey guys!! Sorry im in brooklyn for the weekend.
OP please rethink this! You can order clear vinyl from Rvinyl.com who is a nyc seller and ask him for the pices to be cut. Simply measure the pieces you need.
Application is easy. Use a water/soap solution to spray on the pieces and area you wanna apply and squeegy on the vinyl. Squeegy out the soapy water and let dry.
I did this on my rear bumper with a 12"x4" of clear vinyl to protect my car when i attach the trailer.
followingnfront
Car: 2017 Maxima S
ImStricken wrote:Hey guys!! Sorry im in brooklyn for the weekend.
That sounds good... Do you think if I order this stuff, you can perhaps help me? I can meet you or you can meet me?
ImStricken06
2016 Kia Sorento
I could do a video for you. I promise you its super easy.
You will need an empty spray bottle(dollar store)
Two table spoons of dishwashing soap and water in your bottle.
The vinyl is to be sprayed and your work area.(cleaned well prior)
Place the vinyl on your work area and use a card squeegy to work out the soapy water.
The soapy water will prevent air bubbles to be stuck.
I would help but honestly i have a torn left shoulder and its hard for me to work on cars. i cant even change my oil :(
followingnfront
Car: 2017 Maxima S
ImStricken wrote:I could do a video for you. I promise you its super easy.
I guess I'm just worried about how well it will turn out if I do it. You obviously think getting this RVynil stuff and applying it myself is better than spending $120 for 3M stuff to get installed professionally, so I guess I'll do it. I'll measure the door sills tonight and get call RVynil on Monday. I'll cancel my appt. for Monday for the 3M stuff...
I just hope it turns out well is all.
ImStricken06
2016 Kia Sorento
Try this. Order one door sill vinyl and try it. Tell him imstricken sent you.
ImStricken06
2016 Kia Sorento
I just msg'd him that you will be contacting him for door sills
followingnfront
Car: 2017 Maxima S
Thanks alot man! Do you think I should just get 2the (1 for each side)? Or break each side in halves and do 4?
ImStricken06
2016 Kia Sorento
Id buy one piece and try 1 door. If you screw it up, or cant do it then only a few dollars spent.
But if you do well, order the rest of the doors and do them
followingnfront
Car: 2017 Maxima S
ImStricken wrote:Id buy one piece and try 1 door. If you screw it up, or cant do it then only a few dollars spent.
Well, that's the thing... The door "sill" actually goes the whole length of each side... And it doesn't actually stop at each door, so I was asking if I should get one piece for each side, or basically one piece for the length of each door sill which would mean 2 pieces per side that meet in the middle?
*I'm not sure if you understood my question before but if you did I apologize for stating it again*.
If I do it door by door, It won't be as clean of a look because I'd have 2 pieces meeting in the middle on either side (A minor issue I suppose as you don't drive around with your doors open) and if I do it 1 piece per side it will be a cleaner look, but it may be harder to actually install because I'd be working with longer pieces.
*BTW thanks for checking out my thread and responding so quickly!
ImStricken06
2016 Kia Sorento
well since the door seal, doesn't go the whole span of the rocker-panel, there really is no reason to apply clear vinyl through the whole panel.
id simply measure the area that comes in contact with door seal, and only wrap that area. so id suggest 4 different pieces
followingnfront
Car: 2017 Maxima S
ImStricken wrote: well since the door seal, doesn't go the whole span of the rocker-panel, there really is no reason to apply clear vinyl through the whole panel.
Good call, I'll do it that way. Thank you
ImStricken06
2016 Kia Sorento
that will help make this install a lot easier. i trust Rvinyl. i installed their tint, carbon fiber vinyl on my cars with great results.
ImStricken06
2016 Kia Sorento
good video i just found
[youtube]http://www.youtube.com/watch?v=26Lj8oXILdM[/youtube]
followingnfront
Car: 2017 Maxima S
ImStricken wrote:good video i just found
Good find. Thanks! I haven't measured the door sills yet, I'm going to go down to the car and measure it in a little bit. Then I will call R-Vynil and tell them you sent me
TrevorK
Car: 11 Rogue SV FWD
I personally wrapped it the entire length as I found doing the two smaller pieces was more challenging than doing one large piece. I used the 3M which is expensive so if you can get some clear vinyl then that'll definitely save you a couple bucks.
I assume vinyl work the same as the actual 3M when it comes to removing bubbles (you can use a needle to remove the trapped air and then heat it up, the 3M seals itself back up).
The most challenging part is deciding where to "stop" on the bottom. At first I said "Oh yeah, I'll just wrap it all the way around under the car". Then I saw the dozen or so plastic clips/circle pieces/forget what they are that you have to cut out for. With a 4" strip I ended up cutting it down by an inch I think as the part where the weatherstripping meets the door was covered (up to the angle in the rocker panel) so plan it out well before hand because I hated cutting it on the car.
ImStricken06
2016 Kia Sorento
i would only wrap the 'affected' area. there is no point to try and wrap further than that 1-3" scratched up area.
3m is just a vinyl, and i have never heard of it sealing itself. ill take a look into it. if you apply it with the soapy solution, you wont have bubbles that are a huge pain. i know the area is scratched, so the scratch will hold some air- expect that guys (who are looking to get into this project)
followingnfront
Car: 2017 Maxima S
Hey I'm stricken... Was there someone in particular I was supposed to speak to? I called today and spoke to a lady and I explained that I needed two 1.5" x 41" strips for the fronts and two 1.5" x 24" strips for the rears... She told me to hold so she could ask her supervisor if that was possible, and then she came back on and said, "I'm sorry sir, but you can only get the sizes found on our website"...
Last edited by followingnfront on Mon Feb 04, 2013 7:07 pm, edited 1 time in total.
Qashqai
The affected area is only quarter inch. Two years ago I get some price quotes from local vinyl/clear bra companies. They were about $90-120. I decided to use a high-quality 3M electric tape! I know it sounds stupid, but it works great. I check the tape every 6-7 months and it is not damaging the paint. Since my Rogue is dark gray, black looks good as well.
ImStricken06
2016 Kia Sorento
followingnfront wrote:Hey I'm stricken... Was there someone in particular I was supposed to speak to? I called today and spoke to a lady and I explained that I needed two 1-1/2" x 41" strips for the fronts and two 1-1/2" x 24" strips for the rears... She told me to hold so she could ask her supervisor if that was possible, and then she came back on and said, "I'm sorry sir, but you can only get the sizes found on our website"...
i msg'd the owner to see what the deal is.
check this part of the site out: http://www.rvinyl.com/paint-protection- ... RBp0WfoOSo
followingnfront
Car: 2017 Maxima S
Qashqai wrote:The affected area is only quarter inch. Two years ago I get some price quotes from local vinyl/clear bra companies. They were about $90-120. I decided to use a high-quality 3M electric tape! I know it sounds stupid, but it works great. I check the tape every 6-7 months and it is not damaging the paint. Since my Rogue is dark gray, black looks good as well.
I think its more than a quarter inch... I believe its 3/4" so its safest to go with 1" wide vinyl (or whatever you use)
followingnfront
Car: 2017 Maxima S
Thank you sir! I want to change my measurements to 1" x 41" (front) and 1" x 24" (rear) as I think 1.5" may be wider than needed. What do you think?
ImStricken06
2016 Kia Sorento
when you apply this film, it becomes invisible- so you dont have to worry about cutting it 100% straight. see the measurements he is offering on his site, and order what the closest size to you is.
followingnfront
Car: 2017 Maxima S
ImStricken wrote:when you apply this film, it becomes invisible- so you dont have to worry about cutting it 100% straight. see the measurements he is offering on his site, and order what the closest size to you is.
Ok thanks... To me, the scariest thing about fine-tuning a cut while the vinyl is actualy on the car, is the thought that I may cut too deep and scratch the paint... So I'll measure/cut the vinyl before I start applying it I guess.
ImStricken06
2016 Kia Sorento
done fine tune any cut when on the car lol. just use a razor blade and a straight ruler to do your cuts, THEN apply and the vinyl will disappear once applied. i promise you.
followingnfront
Car: 2017 Maxima S
ok cool... Should I buy any of their accessories with it? I am going to get the squeegee with friction sleeve. Should I get either of the other products? The "Rapid Tack" or "Rapid Clear" for instance? The soap and water pretty much does what those things do right?
ImStricken06
2016 Kia Sorento
followingnfront wrote:ok cool... Should I buy any of their accessories with it? I am going to get the squeegee with friction sleeve. Should I get either of the other products? The "Rapid Tack" or "Rapid Clear" for instance? The soap and water pretty much does what those things do right?
nope, the soap solution will do you well. i WOULD get the squeegee with friction sleeve. i have saved those two and used them on every sticker i apply. i used them to apply my tint too
followingnfront
Car: 2017 Maxima S
Cool! Thanks Im going to order it now.
Return to “Rogue Forum”
