The compression on the S14 from factory is 220 PSI (as opposed to the S13's 180 PSI). . . So my car is fine in terms of wear etc. . . But what about the 15 PSI difference from each cylinder?gigabit240 wrote:Why wouldn't it still have good compression? Im kinda worried about your car though... The compression seems a little high? I think... I'm not sure if its different for s14's
That 179 compression is not the factory rating, it's the average over time. . . If you look on wiki, it states that the 94-98 240's have a compression of 9.5:1, while S13's have 9.0:1. . .motoman399 wrote:well 220 is not the factory psi. i copied this right out of the 95 240sx FSM
Curiosity is what made me test it out. I was always interested in knowing the compression on my engine. But I might just replace the compression gauge, because if you haven't noticed. . . On both my car and Asoomal's 240, every 2nd cylinder was the same. . . SO I think their may be a problem with it.FlatBlackIan wrote:Unless you are having driveability issues, then you are most likely fine. General rule of thumb, for any engine, is 120 PSI to run, and no more than 25 PSI difference between any 2 cylinders.
You may have a slight imbalance in actual power production between cylinders, but nothing should be noticeable. If you have a consult port, and access to a proper scanner, you could try running a cylinder balance test. This will tell you if the difference is enough to throw the ECU off, but my professional opinion is that you should be fine.
What prompted the compression test?
I wouldn't worry about it, really.Jagstang wrote:
But yeah, my engine runs amazingly. . . It purs like a brand new engine, idles well, and has amazing power. But yeah, the 15 PSI difference does worry me a bit.
Well, my future aspirations is to turbo the engine, and if the compression was great all around. . . I would be pretty happy. But I guess that all changed now.FlatBlackIan wrote:I wouldn't worry about it, really.Jagstang wrote:
What are you going to do about it anyway, tear down and rebuild the engine for no gain in performance or reliability?
It is not a problem unless it deteriorates. How would the engine have been if you had never checked it?
It was made for the 95 model year. Just like my 92 was made in july 91asoomal wrote:Probably meant late 94...his S14 was made in April 1994 btw.
You sure they didn't bump up the compression for the S14's?
No not necessarily. Unless you're looking at throwing down past like... 270-280 hp, then you can probably just boost the stock internals.Jagstang wrote:
But then again, I guess I have to rebuild it to handle the turbo in the first place, but still
