Does wheel weight matter THAT much?
DrJuice164
Car: 04 G35 Coupe
Just wondering how much rim weight plays into preformace of a car. I personaly have only driven cars with low horsepower and heavy whees (24lbs each) and those made a noticable difference. But to those with higher horsepower cars, are the weight of the wheel negated by the power the engine makes?
sensibleS13driver
All of these articles are very helpful to what you're wondering, hope they help http://forum.miata.net/vb/showthread.php?t=40082
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
On motorcycles it helps out. I couldn't imagine running a pair of CF Marchesini's. The front wheel is around 3lbs.
*EDIT* I just read this post again. I meant to say Dymag's, not Marchesini...They make good magnesium wheels, but Dymag makes the good CF wheels.
Modified by Looneybomber at 9:25 PM 3/13/2006
DrJuice164
Car: 04 G35 Coupe
Very nice find sensibleS13driver, thanks for the info
InsanityInc
Would you add weight to your flywheel? Then why add weight to your wheels?
Looneybomber
10 G37S (white)
InsanityInc wrote:Would you add weight to your flywheel? Then why add weight to your wheels?
Rock crawlers use heavy flywheels, but that's a totally different story.
sensibleS13driver
haha yea you know miata guys have to find all the power they can, theyre also big into technicalities
audtatious
For every 100 pounds of unsprung weight that is removed, you fee up hp. This could equal as much as -.1 et times. Of course, lowering rim weight and increasing diameter is kind of a push due to additional rotating mass.
At least, that is what I have seen "out there on the web".
Red coupe
Car: 92 Nissan 240sx Coupe
its not just a hp thing, less unsprung weight makes it easier for the suspension to do its job, and the wheel to follow the road...
InsanityInc
Looneybomber wrote: Rock crawlers use heavy flywheels, but that's a totally different story.
Alright, so if you want to build a rock-crawling 240, go for it. Otherwise....
InsanityInc
audtatious wrote:For every 100 pounds of unsprung weight that is removed, you fee up hp. This could equal as much as -.1 et times. Of course, lowering rim weight and increasing diameter is kind of a push due to additional rotating mass.
That's really, really, REALLY wrong.
Unsprung weight is the weight of your suspension and all things not suspended by the suspension (wheels, tires, etc). Lightening your control arms will obviously not gain you any power.
You gain power from lighter wheels because they are part of the drivetrain, so you are reducing drivetrain losses, same as a lightened flywheel or a lightened driveshaft.
Also, dropping 100lbs will gain you a LOT more than .1 in the 1/4. Hell, dropping 100lbs of sprung weight will likely gain you more than that.
nismofly
Car: 89 Nissan 240SX Hatch
anybody know how much unsprung weight the 240 starts with? i bet its between like 200 and 250 if you think about it, and dropping half that is going to help a ton
and also like Red Coupe said its a lot more critical when youre turning
Red coupe
Next person to install springs/coilovers needs to brake out the bathroom scale to give us a rought estimate
nismofly
well its not just that
i figure most wheel / tire setups are around 160 lbs. and everything else is probably 50 - 75 lbs.
when im building my racecar ill probably do some research stuff like that
audtatious
Unsprung weight is pretty much everything outboard of the struts/springs (the wheel/tire, brake rotor, caliper, hub and bearing, etc). You don't "gain" horsepower you free up what you already have available. Wheel/tire combinations that are lighter can impact 1/4-mile performance as there is less mass which requires less torque in comparison to the heavier wheel/tire combination.
StatixNWH
lol the sentra in one of those articles......they completely STRIPPED that thing, make it a convertable and took everything out....that only made them 2 seconds faster....so the question is, do you want style and performance, or just one of the 2
crzycav86
Car: 93 Nissan 240SX KAT
completely naked is sexy
StatixNWH
yeh but thats like a naked fat chick.....you only get one thing out of that....and its sick
nismofly
but its not a naked fat chick, a car with 4 subs and that sort of thing is a 500 lb. girl that thinks shes hot
i wouldnt go to the extent that they went, since you cant actually race a car in the condition they had it in
also it was running on absolutely horrible tires, theyd probably gain another second
however, id take a car with a stripped interior anyday over a car with stuff inside, "bling"
if you really care about performance enough you go all out
crzycav86
but anyway, lighter wheels are very important. first of all, the drive wheels will free up horsepower.
second, you get improved handling by reducing unsprung weight. That means your suspension will react more quickly to bumps, and it will increase grip.
wrong forum.. newb.
McRussellPants
Car: 92 240SX
The same people telling you wheel weight matters alot will be the same people running booty *** FN01s.
It won't make a huge difference. Handling differences will mainly be felt over bumps. Acceleration differences only in higher gears.
Don't worry about it and don't jerk yourself off telling other people your car handles better since you bought the 7in wide wheel instead of the 9 because its 1lb less.
crzycav86
Every surface has bumps and physics doesn't lie.
S14KoukiMonster
Car: 1997.5 Nissan 240SX LE 5spd.
YES- it's proven even bigger rotors can lose significant power.It's simple physics- the bigger the diameter of a rotating mass, the more centrifugal force it has. That's what loses power.
Case Closed! :bonghit
Zion8561
Car: 92 Nissan S13 Fastback
nismofly wrote:well its not just that
I had the front suspension apart yesterday, the front steering knuckle with caliper and rotor probably weighed atleast 30 lbs each. Kinda surprised me when I pulled it off the ball joint
hannibal
Car: Red Line to Glenmont
one more point:Lighter is always better for performance. But unsprung weight has a bigger impact than sprung weight. So removing 20lbs from your wheels/tires/hubs/etc would yield better effects than removing 20lbs from your interior.
I think thats why peope make a big deal about wheel weight (and unsprung weight in general).
skylndrftr
Car: 07 Nissan Versa S
2010 Ariel Atom (pending...)
does anyone have a good database of tire weigths? its not something that is gonna be at the top of the list when choosign tires...But at the same time they are on a much bigger radius than the wheel itself.
gabossie
Car: Your mom
wheelspecs.com has some wheel weights. There is another site that has a more comprehensive list of stock and aftermarket wheel weights but I can't remember what it is and it seems not to be in my bookmarks anymore
Dori Dori
Car: Cars of course
Zion8561 wrote:I had the front suspension apart yesterday, the front steering knuckle with caliper and rotor probably weighed atleast 30 lbs each. Kinda surprised me when I pulled it off the ball joint
They are not that heavy, guarantee it.
audtatious
IWannaS15 wrote:one more point:Lighter is always better for performance. But unsprung weight has a bigger impact than sprung weight. So removing 20lbs from your wheels/tires/hubs/etc would yield better effects than removing 20lbs from your interior.
From what I have seen, unsprung weight is worth 1.7-2x sprung weight. The only problem with all of this is you are talking minimal performance gains. When you are talking a 1/10th of a second decreases, it is hard to validate because of driver "error" or whatever. From a physics standpoint, it is sound.
crzycav86
Dori Dori wrote:They are not that heavy, guarantee it.
A caliper + rotor + spindle/hub is probably around 30 lbs.
