nismofly »
https://forums.nicoclub.com/nismofly-u19497.html
Tue Feb 28, 2006 10:09 am
because i didnt know of any wheel weight sites when i bought them, i put the stock wheels on a scale and they were something like 19 lbs., put the koseis on the scale and they were 14.9 lbs.
the stockers are 15x6 of course, koseis are 16x7.5
the stockers had 205 UHP tires on that were worn pretty well, i think they had about 9k miles on them, i put 225 tires on that were similar in performance
its not that they felt faster really, it felt more stable, which im sure helps time overall...
im not saying wheel weight is the sole variable in the equation, some of the feel could have come from wider tire, lower offset, smaller sidewall yes, but to say that it makes no difference i know is wrong, because i have personally seen that when the same car with 225 hoosiers is running 13.2 lb. team dynamics pro race 1's (the wheels ill be running until i can afford volks), then switches to the volks which are 4 lbs. lighter a piece, still same tires and everything, the difference was consistently around a second less with the volks, over a track normally lapped around 2 mins.
now you may say 1 second doesnt matter, but in ITA where theres 20 or 25 cars prepped nearly identical youll take every second you can get
for example, hoosiers are overall about a second a lap faster than r-comps like toyo ra-1's but everybody that can runs the hoosiers, theyre willing to cough up the extra $150 for a set
ive been looking at this from a "all other things equal" standpoint, in which wheel weight will make a difference...if you get wheels that are a pound heavier but then install coilovers, put slicks on, and up the boost for another 50 hp, sure it will be minute compared to the other changes
i never saw anyone say that though, just "does wheel weight matter," and the answer to that would be yes, if thats the only thing changed
