does cold air intake even make a difference
sexcpr69
Car: 2006 g35x
i have a 06 g35x sedan with 20's and was lookin to upgrade a lil for some horsepower would cold air intake make a big difference because people say it would just sound louder and you wont feel much difference ?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
It can make a difference, but I think that most short ram intake systems don't have sufficient heat shielding. The long tube cold air intakes typically lose the throttle response.
My answer to this was to use the Stillen airbox and the JWT pop-charger. I heat-tape wrapped the entire z-tube, MAF housing and the side and bottom of the airbox. My intake temps are 10-13* above ambient (very slightly higher than stock) and all the added benefit of velocity stack, throttle response and increased air speed and volume.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
It makes a difference. Buy one and you'll see. The difference it makes is all in your perception.
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
You will notice it, but not the same as dropping your 20's in exchange for something smaller and lightweight.
I sold my stock wheels, and I wish I still had them for track use.
I have a medium length ram air intake from Fujita, with the Blox manifold spacer it is intense to say the least. I can break traction pretty damn easy and with the exhaust it's like a new car. Get a setup like tollboothwilley if you want the best results IMO.
BrandAidDesignG35
Just to add, I just put on the 17's on my 200sx in my sig above, noticed an immediate sluggish throttle response, the new wheels are heavier, taller, and frankly all show... but it's a beater so who cares
Get the JWT pop charger, and a Z tube, which is the intake tubing off a Nissan 350Z. It's highly recommended on this site.
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
the Z-tube makes great sound if nothing else... suppose to be a top end hp gain... i can believe it since you are directing air straight into the engine versus through a silencer that the stock intake has. The only "flaw" IMO with the stock intake was adding a silencer...
IMO the best bang for your buck is a 5/16th spacer... these gains are noticable in everyday driving since it effects the mid range. It is also a sound increase though, which i happen to love...
I combined them both.
sexcpr69
Car: 2006 g35x
where you get the heat tape at ? and the rest of those things at a good price send me a link
tollboothwilley
I started out with the JWT pop-charger and heat shield new. The filter is awesome and so is the velocity stack. I didn't like the heat shield at all though. So I bought the Stillen intake new. I kept the airbox but sold the JWT heat shield with the stillen air filter & velocity stack. If you're lucky and pay attention you can find the stuff used for about half price.
Problem with the intake is you need get both intake systems and sell off the extra. Higher initial cost.
Finally, I wrapped it with the tap here:http://www.heatshieldproducts.com/tape_index.php
I used the heat shield tape. Get some of the "cool foil tape" use between the lines. I didnt, and now I wish I had.
Here's a pick of what mine looks like, I painted the heat tape black to match the rest of stuff.
sexcpr69
Car: 2006 g35x
ok willy lets say u had to pick one or the other which one would you go with and between what lines to tape and what else do i tape ?
tollboothwilley
If i had to choose 1, i'd go with the JWT heat heat & popcharger.
I would use the heat tape on the exposed velocity stack though. Since its metal it will conduce the most heat and bring the heat into the intake air.
When you use the heat shield tape I didnt overlap. The connecting sections i would use that cool foil tape to keep the fray down.
sexcpr69
Car: 2006 g35x
okay thanks for all this good advice and could you send me da link for the one that u recommend and just to make sure the z tube you talkin about is the plasic lookin one right not the hard metal lookin one? and how do u post a pic of your car i keep tryna but all i get is dis wen i click da pic on da top [IMG][/IMG]
tollboothwilley
z-tube is plastic...just replaces the stock G-tube.
If you want to post a picture you need to have a host....upload your photos to http://www.photobucket.com and then copy/paste the IMG url.
http://www.conceptzperformance...e=G35
you might be able to find a better price, I dont remember what I paid for it
take a look at some of the sponsors of nicoclub.com and tell them you're a member here
cypherlock
Car: 2005 G35 47k miles, 1997 740il 150k miles
After lurking on this forum, I got a JWT Pop Charger and Z Tube off E-bay. It took me about 30 minutes to install both because my neighbor was harassing me. ;-)
I couldn't be happier. Car sounds great on acceleration, seems much stronger and faster. You will notice a difference if you are used to the way your car drives now.
My 5/16 plenum spacer is on it's way, really can't wait! <grin>
Only one problem so far: SLIP- No VDC and Brake lights came on, meaning I need to check rear brakes and brake fluid. Lolz!
BrandAidDesignG35
My neighbour usually brings the beer, tools, and lights if I'm out working late on the car
tollboothwilley
I wish my neighbor came bearing gifts! I'm always doing work on my family's vehicles now. I've become the "go to" mechanic somehow.
kmckis1029
cypherlock wrote:After lurking on this forum, I got a JWT Pop Charger and Z Tube off E-bay. It took me about 30 minutes to install both because my neighbor was harassing me. ;-)
make sure you use a torque wrench when you install your spacer...
sexcpr69
Car: 2006 g35x
why did the slip and vdc and brake lights come on because of the cold air intake?
BrandAidDesignG35
tollboothwilley wrote:I wish my neighbor came bearing gifts! I'm always doing work on my family's vehicles now. I've become the "go to" mechanic somehow.
With knowledge comes wisdom, with wisdom comes your friends and family looking for a tune up or oil change
Isn't that the way
BrandAidDesignG35
My best bud from way back just picked up a 03 G35 sedan, I'm going to take some pics etc later tonight...
He's going to milk me for all my knowledge you can BET!!!
Potomac-Greg
Car: 2009 G37 Convertible
Most mods like this make your car seem faster because of all the padding and weight you've lost from your wallet!
Seriously, why buy anything without seeing objective stats before/after?
Car companies work pretty hard on intake systems and they have lots of resources. Why would they leave the HP on the table?
sexcpr69
Car: 2006 g35x
hey willy i was lookin on ebay and i was checkin out other fiters and systems and i was wonder whats the difference between the filter being lubricated with oil and one that you dont use oil on they were saying that its better i also looked up dis one says u get 17 more hp http://cgi.ebay.com/ebaymotors...ories do u think this is better then the z tube jwt charger
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Sexcpr69,
On a dyno the Fujita short ram adds 9 hp. Where is the RPM band does this power come? Right before redline the power is added but you only experience it right before the shift so its kind of lost in the redline drama.
The idea behind the aftermarket filters is simple. They are designed to allow more air into the motor then a stock air filter. If the motor can get more air the airflow sensor will add more fuel. More fuel = more power.
The G is pretty dang effient already what with two air boxes and two throttle bodies. To really get noticiable power out of the G you would need to change more then just a air filter.
Adding headers and removing the cats, freeer flowing mufflers in combination with a higher flow air filter would be your best bet. Then add a 75hp wet nitrous kit
gwoods
Get a second set of rims for driving fast cause 20's are all for looks.
Get 17x9 Mustang Bullitt rims. 245/35/17 tires front and 275/40/17 tires rear
tollboothwilley
Jeff, you forget only the 2007+ sedans and 2008+ coupes have dual air intakes. Its been a long time since I've seen you around.
Sexcpr - The HKS filter is good for HP because it filters TERRIBLY. Its the worst kind of filter medium out there. I think that intake looks pretty, and it had some heatshielding with the silicon hose. It doesn't have a velocity stack though, and that filter will let in more crap than you want.
Potomac-Greg
gwoods wrote:Get a second set of rims for driving fast cause 20's are all for looks.
So Mustang wheels fit on the G series? Interesting.
gwoods
Man I'm back and I jack a thread on my 2nd post!
G_whizz
Car: 2010 G37 Coupe Sport
No one on this site tracks their G more then Jeff (Gwoods) he has worn through more rubber and experimented with different things more then anyone on here I know! (referring to cars btw )
And it's great to see him back!
sexcpr69
Car: 2006 g35x
hey willy whats the velocity stack it comes with the jwt . i think i finally figured out how to post a pic here i go [IMG][/IMG]
sexcpr69
Car: 2006 g35x
yea these are just 4 show
tollboothwilley
The velocity stack is the piece of metal that the filter wraps onto. It makes the air flow smoothly into a 3" pipe from a 6" diameter filter.
