lucidd »
https://forums.nicoclub.com/lucidd-u85156.html
Sun Feb 24, 2008 8:18 pm
you do pose some valid questions.,, so firstly, although id love to take credit for my post, the ideas actually come from road&track's tech tidbits section- from an issue- years ago when i had a subscription... i'll elaborate a lil more on what i remember- the acid comes from condensation during or when the engine coole down- H2O is also present from gas: hydrocarbon+oxygen=power&water: but other gases are involved*like nitrogen (nitrogen oxide) &unburnt hydrocarbons &carbon [sut] which all mixes together to get an acidic formation in the combustion chamber. this acid will exist thru a long or short warmup---but--- in a slower,longer startup (letting idle in mornng for extended period) will allow the acid buildup affect the engine more*so than a quicker warmup. exactly how? .. im not a chemist, nor do i remember what the r&t article sed... but makes sense to me, & r&t has always been acurate with their words. . . as for the engine being the only thing affected by the temperature...pls elaborate- not sure exactly what you mean, but/// really, anything and everything that is lubricated by grease or oil... needs to be warmed up-primed before the oil/ grease can lubricate/ protect properly... now here comes the theory: if one warms vehicle up for 4-10 minutes(or more), he/she would depress one's throttle *more*than> if one was told to take it ez-slow warmup, stay below 3k.rpm,with less than half throttle:::::this second way of warmup would enable all of the vehicle's moving parts-to warmup its oil/grease and allow a better*protection to the vehicle. ,,,,should be better* cuz we all know that cold oil/ grease (unless designed to lubricate at extreme low temperature only* which no automotive grease/oil is speced only for low temps) does not work/protect at low temperatures........ hope this makes sense .....L
