SeanDean »
https://forums.nicoclub.com/seandean-u1148.html
Wed Mar 24, 2004 9:44 pm
I love all you guys who say things like "I am sure blah blah...." or "there sure seems blah blah...."
For those of you who are wondering what these bullsh!t speculationists mean, let me translate: "I don't know s***"
I like this one: "The clutch is there for a reason...yadda yadda"
Yea the reason is to transition the car from stationary to moving, and it also makes shifting easier when you have a syncromesh transmission. I don't know what you guys would have done before syncros. Ever hear of double clutching? Well even when you double clutch, you can grind gears because clutch in or not, revs MUST be matched, so in reality most people with non syncromesh trannies back in the day, just shifted clutchless with good rev-matching.
For you people saying that clutchless shifting is bad for the transmission and bad for syncros, you obviously have no idea how the tranmission functions in the first place. Proper clutchless shifting actually causes less wear on the syncros than regular shifting. Regular shifting forces the syncros to speed up or slow down the input shaft and clutch disc, whereas rev matched clutchless shifts (the only way to do it properly) match the revs of the engine, flywheel, clutch PP/disc, and input shaft (since they are never disconnected) to the speed of the layshaft for the next gear. That creates no wear on the syncros because they have to do NOTHING, and the gears just slide in.
Now if you are learning clutchless shifting with no understanding of how the transmission works and you cant adjust engine speed finely AND you put pressure into the gear you want to go into before the revs are matched, this WILL cause more wear but IS NOT proper technique.
A quick 2nd to 5th upshift with the clutch would cause a great deal of syncro wear, but without clutch and allowing engine speed to fall to the right rpm, then sliding it in; would cause practically no wear at all. Ultimately the clutch has NOTHING do to with syncro wear. Relative gear speed DOES.
And as for chipping gear teeth....... HAHAHAHAHA, clearly the people saying that don't know what the phrase 'constant mesh' means. In a modern transmission, all the gearsets are always meshed and the only thing you are sliding back and forth are the dog rings. That's what you hear grind, not gears, and dog rings are extremely tough so you would be hard pressed to damage them.
Educate yourselves before trying to comment as if you are some sort of authority.
Oh, and BTW, Nissans DO have syncros on first but they aren't the greatest. Only cars I know of to have syncros on reverse are BMW's but I'm sure some other cars with ZF and Getrag gearboxes have reverse syncros.
Cheers,-Sean
