SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Thu Jul 10, 2003 3:41 am
SkillaSX: There are many issues involved with wheel fitment and the effects that take place when you deviate from original equipment.
The first rule(although rarely followed, much to the chagrin of the car's owner) is to decide on ride height, custom body work(body kit you mentioned), and THEN pick a wheel that fits the car.
Find custom wheels that fit the car, DO NOT modify the car to fit the wheels!!! But wheels LAST!! You have been warned, and I hope I don't see your wheels in the B/S/T section in six months:D
Next, rolling mass/unsprung mass(heavy 18" wheels), are the enemy of low torque economy cars(240sx, similar 4 cyl compacts). I'll wager that each member probably has a buddy who's Civic is now slower because he *just HAD to have* the bling heavy wheel. A very expensive lesson to learn! A greater contact patch DOES equal greater rolling resistance. This, along with heavy wheel weight, means slower launch/acceleration/BRAKING. Of course there is a fine line that OEM manufacturers walk when deciding what tires/wheel size to design a car with. Hitman's Q will benefit from stickier rubber and slightly larger contact patch; a <relatively> lightweight economy car will suffer from greater contact patch, and will likely never near the limits of grip, even OEM grip... except for the occasional, intentional, burnout...or intentional *drift*....
Meantime is right when he says "no bigger than 17". Anything more is REALLY overboard when considering heavy wheels and their ill effects on handling, acceleration, and stopping(the most critical, the most overlooked).
J-spec tuner is correct saying that "cheap 18" rims are heavy, poorly built, bend easy, harsh ride" All true. BTW, cheap 18" rims are still quite expensive. The cost of quality(Volk, Fikse, RH) 18" rims will set you back about what you paid for your car.
There are exceptions, but most 240's don't have the torque to require(or use effectively) such a large contact patch. When you consider that acceleration and braking will suffer with over-sized heavy wheels, where is the benefit? Looks?
Please remember to at least maintain overall tire diameter. Changing tire OD affects the speedometer, odometer, and the "effective axle ratio"...again robbing your car of the already anemic torque output.
The idea that you need to upgrade your tire/wheel size in direct proportion to upping your engine's HP rating is pure myth. There are many soft-compound tires available to fit on stock or near stock sized wheels. Cars with sticky rubber and smaller wheels will generally out-handle, out-accelerate, and out-brake the big show wheels. It's great to see how many replies are in favor of the reasonably priced upgrade to 16" or 17" wheels instead of bigger, heavier 18".
