SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Thu Jul 10, 2003 3:41 am
ACK!!
I thought I mentioned this problem in my previous post, but perhaps you were bored reading it and skipped over...
Changing your tire's Overall Diameter(OD) changes your car's "effective axle ratio". Meaning, that instead of actually changing the pinion/ring gear ratio, you are altering the tire's revolutions per mile ratio. The result of putting a larger tire on is the same as altering your axle's gear ratio, so it is called the "effective axle ratio."
If you put a taller OD tire on your car, the car's effective axle ratio becomes numerically lower, giving you a higher top speed(barely, you won't notice with the changes we're talking about here), and also slowing acceleration time. The reason for the slower acceleration is you have now lengthened the "arm" that the engine's torque must turn...not to mention the added weight of big rims... That is the simplest explanation i can think of at this early hour.
Notice that if you put on a smaller tire, your top speed would be lower(again, ever so slightly), and your car would feel as though the engine has more torque. By using a shorter tire, you have shortened the length of the "arm" that the engine's torque must turn.
Rotational mass can also be called rolling mass. Any increase will make your car's components work harder than intended....thereby causing your car to feel less responsive. The usual suspects are affected: engine torque feels lower, because of greater weight that the engine's torque must now turn(causing the car to "feel" slower on acceleration), and braking will suffer, because the brakes must now slow the turning effect of a greater than OEM-intended mass(your heavy wheel).
If you want some easy proof about mass and how it affects responsiveness:
Take a bowling ball and a basketball...throw each one at your best friend as hard as you can. Which ball accelerated with the least amount of effort? Which ball was easier to slow down when your friend tried to catch them? Imagine the extra work an OEM-grade car must do when you add rotational mass.
A crappy analogy, but you get the idea.
