roworld »
https://forums.nicoclub.com/roworld-u88429.html
Tue Feb 05, 2008 3:10 am
[QUOTE=302VertMan]This is my recent E-mail to Black on Gold (NICO Member)Ive had alot of questions on the 302 swap so here we go....
whats up man. I've had alot of people asking me about the swap, and honestly im just a 19 year old kid trying this swap out in my yard. I've done the whole turbo thing on my old sohc, witch gave me alot of mechanical and fabrication skills, so it's making this swap a little easier.
My project is at a standstill right now, mostly because i've ran into another problem. I decided to go with an auto transmission, mostly because the one that came with the drag motor has a shift kit and other junk in it to make is just about better than a 5spd. the problem is that with the auto transmission's bellhousing being so much bigger than one on the 5spd mustang transmission, it makes it so the bellhousing on the transmission hits the firewall at the same time that the oil pan hits the power steering rack (on a mustang, the power steering rack is in front of the crossmember and the tunnel on the body is bigger so the transmission fits well). Because of this problem i am going to have to cut a decent chunk of the oil pan out to make it clear the power steering rack, and i may possibly have to cut/ or beat some of the firewall out for even more clearance, but i haven't had the time recently to do this. This is all a new experience for me so I am going to post my ongoing info on a 302 swap thread, so please keep updated on the new 302 thread and keep me posted on your ideas towards the whole 302 swap.
Ok first of all, why a 302 vs a 305 or 350
1) More stock hp and tq vs. a 305 chevy2) better stock rpm capabilities than the 3053) front mounted distributor makes install alot easier4) and even the most diehard chevy guy can admit that the 302 has the ultimate performance sound, Ford's cylinder head design helps this out alot. (im a diehard Chevy fan, and i dispise mustangs, but the 302 was a no brainer. The Chevy motors are great, but are mostly designed for trucks. 302's are more performance oriented. Plus every junkyard has a 302 laying arround)
Next, why American Muscle vs sr/rb, and ka power. 1)Anyone who has driven a car with more tourqe than horsepower can explain this one to ya 2)lets go over my build cost so farBuilt engine and built transmission out of a 13.2e/t mustang $200Barely used Edelbrock carb $50Ford 9"rearend freeCrane blue anodized roller rockers $50250 shot zex nitrous kit and zex purge $300(These prices are not "once in a lifetime, great buy prices, you can get a great deal anywhere, you just have to look)Cost of perfectly running 1993 240 Convertable $1000
Total build cost so far $1,600Cost of having the ultimate 240 vert/302 nitrous fed monster = Priceless
On to the Build
First step:
-Remove old engine transmission, and exhaust but leave all wiring harnneses uncut and leave the harness' installed. -Remove all ac lines, radiator, ac radiator, all intake piping from out of the fender, the coil pack, etc.(pretty much remove everything out from under the hood except for the wiring harnesses, fuse box, and brake stuff. LEAVE ALL POWER STEERING STUFF IN THE SHELL!!
Step 2. Making all electrical components work.
-As you will notice, when you hook a battery up to the empty shell, everything electrical works when you turn the key ecept for the top (vert only) and parking lights. Here is how you fix that: -Under the 240 FAQ at the top of the 240 and silvia page, go to the (how to swap out your auto transmission for a 5 spd post) It will have all the pics and info you need.
Ok Now...
-Remove the stock engine mounts. They are connected with a single bolt (you can't see it unless you're under the car) -Powerwash the whole under hood area, trust me, the install will go alot easier when you can see everything clearly, and this also gives you a chance to paint under the hood. The outside of my 240 is going to be black, so i recently painted under the hood gloss black.-
Thanx Chris (302vertman)
What I need to know is what kind of budget would I need to make this happen. How about the k member, transmission tunnel, drive shaft,wiring and all the other stuff that goes with a swap. I have a wrecked 91 gt and Im seriously thinking of doint the swap but I need to have a better idea of what im getting into.
