i'm still researching so your input would be great.
again, car is:- a daily driver for 99% of the time. other 1% due to the after affects of the Initial D and Maximum Tune arcade booths goes to some hard cornering- tires are of 205/55/16- owned by a student with a $23,744 loan to pay off in the next 5 to 6 years- car is 1990 s13 with over 180,000 miles, so its old duh
theorized suspension is:- ksport gt lowering springs w/drop rate of 1.8" front and rear- kyb gr2 dampeners- strut mounts and front/rear strut bars (brand unknown yet for bars)- energy suspension bushing kit AND endlink kit from AutoZone (taken from this DIY
zerothread?id=285052 )
theorized answers for this setup that need to be confirmed are:- to fix the camber issue, all i would need is to take it in for an alignment- if i thought it would benefit, even if i brought it in a shop for alignment, a camber kit really isn't necessary for this setup- toe and caster are not an issue at all should i choose to go with a basic setup for a 99% daily driver like me- strut mounts aren't necessary since the vehicle has oem strut mounts already and can be applied with the kyb shocks/struts- using oem strut mounts will work with any strut bar brand- application of the parts listed in the DIY link provided earlier applies to not only the s14, which i assume was the car on hand, but can be used on my s13- with the DIY application, there's no need to buy new swaybars (though it wouldn't hurt)- the spring rate of the ksports fall within the acceptable range for the gr2s, resulting in NON-blown shocks/struts after 5k miles of daily driving
with all of that said, i should be good to ask santa for some needed parts right? i hope u guys give me the on everything i theorized
i took in my understanding of toe, caster and camber from this site
http://www.ozebiz.com.au/racet....html cause i couldn't really find anything on howstuffworks or even on here
