At least one of you admits that sh*t FINALLY...krash wrote:lowering springs aren't that expensive. At least for us Hon*ahem* 240 owners that is.
cut your springs, it's the same as using those clampsW O T wrote:Mines 2wd btw
I have some stock OEM Altima coupe 2.5S springs if you want to try out to do custom springs setups lolW O T wrote:So you missed the part where i said I want to be able to go to stock in the winter?
I also dont have tight wound coils, there are only like 7 coils on the spring, so they wouldnt be completely compressed I dont think
Make sure your ears are wide open for creeks or anything unusual.Let us know.W O T wrote:Yeah like you said, there fairly common here, but Ive only ever seen people use them to lift. I dont mind the look, you wont see them, and I will paint them black
Was just curious on the ride quality, I'll try them out I think, for $35 and an hour or 2 to install properly, aint got much to lose
I doubt it will unless it's really crappy material.Or if one nut falls and stuff.krash wrote:I'd honestly be worried about them breaking under all that stress while driving. That wouldn't be a pretty situation.
Hey, don't make fun. It's cold in Chicago.AZhitman wrote:
If the OP thinks he'll notice a 3/4" drop, he's got a better eye for measuring than most women.
If you are looking to change back and forth with the seasons you shoyuld look into what kind of alignment changes occur with ride height. I know that my Titan sees some rather large changes to the toe angles when lifting slightly. Even going back between a 3/4" drop and normal ride height would likely increase tire wear significantly on it. Not sure about the QX4, but make sure this will not be an issue. If it is and you want to proceed, you should consider the cost of an alignment each time you adjust the height.W O T wrote:So you missed the part where i said I want to be able to go to stock in the winter?
Greg your asian now.W O T wrote:Thanks for atleast looking for my aznhitman
