yeah I'm starting to ask the same question. I've change oil on previous car and this one shouldn't be any different. thx.Manok wrote:Don't know why you'd go to a dealer for such an easy job unless you have money to burn.
Yeah. It is one of the reasons I change the filter every 3750 miles too. No reason to keep it in too long at all!Manok wrote:also shocked at how small the filter is.
Hmmm ... I did not switch to gain more miles between changes ... for me, it was to get a consistent, high-quality oil, that would treat the engine right!DRIPS wrote:I was thinking of switching to synthetic oil from the conventional 5w30 i always use. Is there any bad things if I switch from conventional to synthetic oil? I have always changed my oil every 3000 miles.
HOw far can I go on synthetic?
Agreed. Which is why I use them for the 7500 interval. My local Infiniti dealer gives me a discount for the oil change at that time too, since I take in the Mobil 1 0W-40 for him to use!nmgoodthing wrote:Although I am not running Syntetic oil, I find that paying $54 for an oil change and getting a loaner car is worth it.
The dealer also checks for other things that could be wrong that you do not know about.
Also agreed! Most definitely please avoid places like Jiffy Lube!!!!nmgoodthing wrote:If I had time I'd probably do it myself, but I'd be damned if I ever take my car to Jiffy lube or something.
$54 for synthetic at Garcia Infiniti?!?! ..and a loaner !! I get a cookie and get to sit in the M35x in the show room. But seriously Jeff, I could have sworn I got charged $80-85 on my last syn oil change. I'll check my recordsnmgoodthing wrote:Although I am not running Syntetic oil, I find that paying $54 for an oil change and getting a loaner car is worth it.
He definitely does!Mark Linkous wrote:Wow, I did not realize my local dealer offered such a good deal.
Hope you stocked up!Mark Linkous wrote:I just dropped of my car for a oil change. Autozone had a special on Mobil 1 for $4.99 per quart.
I believe so - the exact part number should be in the Owner's Manual too (or the Service Manual ... see link in my sig). It is small, yes! Hence my reason for changing it at every 3750 miles when I get the oil change done.gibz4 wrote:Does anyone know the part # for the 06 m45? They gave me one and it looks so tiny for a V8.. Part # was INF 15208-9E000. Is this correct?
Nice!! Every time I go to Walmart, they never have the 5 qt jugs of the 0W-40 at the ones near my house. I end up buying six of the 1qt bottles (note that you need almost 6qts for the M45).gibz4 wrote:Also i got Mobil 1 (0-W40) 5 quart jug from Walmart for $22 bucks!!!! The shelf said $26 but the receipt came out to $22 each..
I got 2 5 quart jugs just in case, i'm sure i'll have to add a few drops before the next oil change anyway... Funny how the Infiniti parts guy didn't know how many quarts i needed when i asked him to make sure.szhosain wrote:
Z
Good point!gibz4 wrote:I got 2 5 quart jugs just in case, i'm sure i'll have to add a few drops before the next oil change anyway
Hmmm ... that is unfortunate. The M45 needs 5-7/8 qts according to the Owner's Manual ... so, I put all 6 qts in (1/8 qt extra is not excessive. )gibz4 wrote:... Funny how the Infiniti parts guy didn't know how many quarts i needed when i asked him to make sure.
i do the same thing; i just put in all 6 quarts.szhosain wrote:Hmmm ... that is unfortunate. The M45 needs 5-7/8 qts according to the Owner's Manual ... so, I put all 6 qts in (1/8 qt extra is not excessive. )
Z
Z the size of the filter is not so important. Its whats in it. If you're pushing the oil through paper it takes up a lot of space. This is a micopore filter. The Amsoil filter is the same size. Amsoil stands behind this filter for 25,000 miles with their full synthetic. They have lots of data and chemical analysis to go along with their claims. The smaller size micropore filter has similar interface that larger conventional filters have and exposes the entire volume of oil to increased circulation cycles. Synthetic oils don't burden the filters with degradation products. Synthetic oils don't degrade they only get contaminated from byproducts of gasoline combustion. These filters are more than adequate to filter oil for much more than your beloved 3750 OCI. its more science than just traditional notions. But then again you apparently check the tire pressure at a frequency that is a bit over the top. Do all the soup labels face forward in your cabinets.szhosain wrote:
Yeah. It is one of the reasons I change the filter every 3750 miles too. No reason to keep it in too long at all! <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... /frown.gif" BORDER="0">
The 4.5 liter engines in the first and second-gen Q45's had bigger filters.
Z
Z
