Hello,
I'm interested in solving of the problem, too. Unfortunately, I can't find any information of the Consult data port.
Herehttp://
www.wmrc.com/businessbr...8.pdfthey mention 9600 Baud rate but I'm not sure we can trust them.
I had a quick look at the signals with the oscilloscope but there was no activity on the Rx/Tx/Clk lines. All I can guess from my research is that Clk line seems to be an input (active high), Rx - input (active low), Tx - open-collector output (active low). Logical evels are most likely TTL or CMOS (3.3 or 5V). So, direct connection to RS232 seems to be a bad idea.
Then I tried to feed 9600 Hz clock to the Clk line. Still there was no activity on the Tx line. Maybe ECU has to be turned to the diagnostic mode first, may be there is no data downloading without request to ECU.
Any help or ideas are appreciated.
