Discussion of E-Brake & Speed Sensor Override (instructions in "Stuck" thread)
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
jwlthief
I would like this as well. I dont have Navi, but would like my passengers to watch my iPod video while moving. thanks!
[email protected]
UnMaTcHeD
Car: 2009 FX35 AWD Blk/Blk
Please me the instructions as well, my email is [email protected].
Thank you in advance.
benster013
Car: Infiniti EX
hey zozo can u plz send me a copy as well ?? thanx a lot
jwlthief
where are you zozo?
can anybody who has received his e-mail forward it to me please? much appreciated!
[email protected]
moster888
As a new EX35 owner I think that it is great that there is this type of exchange!!!!
And especially to Zozo for helping a brother out!
Love to get my hands on the email to allow me to have my passengers watch the iPod on the road.
[email protected]
Thanks Zozo!!
dividedhighw
Car: 2008 EX35 AWD (Technology Pkg)
OK, everyone ... no more emails ... CLICK HERE instead.
Cheers,David
Roy Cya
Car: 2008 EX35 Journey / 2006 Acura RL
Hey Zozoka,
As a new owner and member I thank you and others like you for sharing good stuff like this with anyone and everyone that asks...
Please add me to the list of folks to send the files to. My email addy is: [email protected].
Thanks!
dividedhighw
Er, Roy ... what exactly did you think I meant by "no more emails"?
geminiash
Car: Infiniti ex35
Pleae send the picture instructions mentioned in your email for disable park requirement for GPS use and video playback . I really appreciate it. Thanks
geminiash
Car: Infiniti ex35
Please send me the email. [email protected]
dividedhighw
Welcome, geminiash ... have a look at the 3rd post above your first one.
geminiash
Car: Infiniti ex35
Thaks for your help with the instructions. Have you tried to make the change? If so does it work?
bokingwen
Car: Infiniti EX 35
wow, this is great info but I am not that sure I am techie enough to do all that. Thanks OP!
voltron22
Car: 2007 G35x
I was attempting to perform the e-brake and vehicle speed sensor override on my 2007 G35x, and I had a few concerns. I can't shift the car into drive w/o starting it, as opposed to putting it into drive with just the accessory power on and e-brake engaged. So, when I do turn the engine on and put it into drive and then turn the engine off, an alarm sounds. Is there another way to perform this step without sounding the alarm? Or am I just a moron and doing this wrong - be honest.
And just for the sake of clarity, ground both the e-brake and VSS pins that feed the plug? Then insulate (wire nut or electrical tape) the exposed wires coming from the chassis?
Thanks!voltron22
gloa2000
Car: 04 Maxima SL, 08 EX35 LuxNav
dividedhighw wrote:Welcome, geminiash ... have a look at the 3rd post above your first one.
I have EX with NAV, and the car in pictures appears it does not have one, is it same procedure?
dividedhighw
(This was answered off-line, but I'll provide the answer here, in case any others are reading this.)
voltron22 wrote:I was attempting to perform the e-brake and vehicle speed sensor override on my 2007 G35x, and I had a few concerns. I can't shift the car into drive w/o starting it, as opposed to putting it into drive with just the accessory power on and e-brake engaged. So, when I do turn the engine on and put it into drive and then turn the engine off, an alarm sounds. Is there another way to perform this step without sounding the alarm? Or am I just a moron and doing this wrong - be honest.
You need to press the "Start" button twice without pressing the brake pedal, to put the car into "On" position without starting it. Then put the e-brake on, and you can safely shift it to "Drive". Now, press the "Start" button again, to turn the car "Off".
voltron22 wrote:And just for the sake of clarity, ground both the e-brake and VSS pins that feed the plug? Then insulate (wire nut or electrical tape) the exposed wires coming from the chassis?
You got it.
Cheers,David
dividedhighw
gloa2000 wrote:I have EX with NAV, and the car in pictures appears it does not have one, is it same procedure?
If you have downloaded the files, read the text and you'll see several places where it refers to how vehicles with Nav differ.
HTH,David
gloa2000
TY David, this is very easy process comparing to other mods i have done with my other cars.simple question, would this mod allow me watch videos while vehicle is moving? or will it only allow me to use NAV grayed out buttons(along with the bth keypad options and more) when the car is moving? since I am only interested in playing my ipod's slide show when im driving.
Thanks in Advance David, TY for opening eyes of the EX noobs
bedn0009
Please email me as well. [email protected]. Thank you.
dividedhighw
Welcome, bedn0009!
No more emails - look instead at the "STUCK" threads on the front page of the forum.
Cheers,David
gloa2000
Does anyone have success story in this mod?
sanddigger
Car: 2007 G35x
Hey zozo... I've got an '07 G35x, no nav. If your 'bypass' instructions apply, would you mind emailing to me (mrenaud<at>karetech<dot>com)? Thanks!
Gesemail
Car: Infiniti EX35
So I haven't actually tried this mod, But...
I have an EX 35 with Nav+Tech.
I went to a garage and asked them if they could make my car think its not moving at all times. They told me the car has a giroscope that it uses to know when the car is in motion. They make parts that are connected in between the giro and the car's "brain" to fool it. They said they have parts for other cars, but one hasn't been fully developed for the new EX yet. Not sure if they are 100% correct or not. The giro thing makes sense, but the question if anyone else can do it for me, I plan to keep looking.
Also just FYI, they told me the part is about $75 and then labor shouldn't be more than an hour. So, at least in my eyes, I would rather just pay someone to do it.
(completely not relevant, but they just had so many Christmas Icons I felt like I had to use one)
dividedhighw
Hey Gesemail,
One of the wires being "modified" is the Vehicle Speed Sensor (VSS) line which sends a pulsed signal as an indicator of vehicle speed. Just download the PDFs and have a look.
Cheers,David
caseyj222
can someone email me the instructions for disabling the motion sensor gps?
[email protected]
gmason001
Car: 2009 Maxima with Sport and Tech packages
zozo...would love to get information with regard to the above title. any idea if the info you have would pertain to a 2009 Maxima?
G
grande2093
Car: 2009 Nissan Murano
If anyone picks this up. Is it possible to send me the link to accomplish this? I know there are several people out there that have it done. I just want to use the component inputs in the arm console.
gloa2000
any success story yet? I will be doin it this weekend, wanted to see some success story before i mess with my 40k toy. otherwise i will update with my story next monday.
willember
Car: EX35
What effect does doing this mod have on the vehicle warranty?
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
willember wrote:What effect does doing this mod have on the vehicle warranty?
It shouldn't effect your warranty, but when I did this mod on my Armada, I completed this mod using the relays, therefore there is an off (stock) position on the switch, and an on (mod) position. This way by the flip of a switch the vehicle can retain the factory wiring and position. I did a similar mod to my '04 QX56 and I never had any warranty issues.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
