dash wrote: a, say 350hp turbo doesn't need anywhere near that amount of renditions. Finely matched? Fail again, even amidst the GT2xxx cloud of confusion, there's NO magicCan't just say "get a 2871". Wanna do the honours... spec the exact one then ?
GT2871R 71mm, 48 trim, .60 A/R compressor. .64 A/R Turbine housing.
http://www.turbobygarrett.com/...1.htm
The 48 trim puts the compressor in its sweet spot for a wide range of the CA's operation and will haul a** to redline while the .64 A/R housing will be good for spool.
As I said before, it's not that I think the oldschool journal bearing turbos suck, they don't; I think they're awesome, especially for what you pay. I simply dispute your argument that all the different variations of the 2871r are, at best, marketing department fakery. Take a look at the compressor maps of all the different variations of 2871r's, the 48 trim wheel is radically different from the 52 trim wheel because they're designed to flow differently through different ranges to suit the different flow characteristics of different engines being used for different things.
Which is exactly why there are so many T3 variations out there! There is no "one size fits all" with turbos but it just so happens that the T3 frame was ubiquitous enough, with enough variations that it became exceedingly easy to mix and match components to reach the desired characteristics when operating on a bunch of different engines. Clipped wheels and whatnot are all ways of changing flow characteristics of the turbo, just like A/R and the design of the wheel itself (which, in case my point is still too vague, is exactly why there are so many different 2871R's to choose from)!
You sound like you think you're among a small group of marginalized people who've refused to buy into the Ballbearing cartridge orthodoxy that's been sucked in by the marketing department at Garrett. It's kinda absurd. I've seen first hand the wonders that Holsets and a bunch of other "unconventional" turbos can do on engines like ours but it's not because the center section is inherently superior or inferior in design.
