dash wrote:TOO MANY CA18s exist to be wasting money "guessing" on assumptions. Bad advice imo.Two totally different motors at that. On one hand you embrace the variety offered... then on the other, you suggest "CA is close enough to an SR" ? Get real.
You are familair with the concept of the "ballpark," yes? You're right to say the engines are different but throw the same turbo on either engine and they ain't all that different. The train of thought is nothing like "Oh, 1.8 is close enough to 2.0." More like "Ok, so SR's really like this turbo, my engine is a tad smaller so it won't work quite as well, but close. Furthermore, the math agrees with that hypothesis, blah blah..."
dash wrote:yes, and u won't make the torque, as high or as early. Don't dwell on peak hp.EVERY street monster I've seen ~26-30psi. Exactly how small turbos put up impressive ETs for what they are, should the urge arise.for example;Cortina MKI mentioned aboveSome heavy 2L 3-3350 pound street DSMs down into mid 11s, puny evoIII 16G! From observation, a CA18 + E3-16G S13 will surpass that considerably, with same effort.You can keep your response, AND crank it up/rip it up. Your choice
The retarded part of this debate is you and I actually fall on pretty much the same side of it. I simply disagreed with you that the innumerable variations on the 2871 were without merit or purpose. Personally, I'll probably never run a brand new Garret GT28 framed turbo but that's because I have a soft spot for cheap s*** that rocks.
dash wrote:Quote »There is no "one size fits all" with turbos
End of debate!!!! Neither is a 2871.... as you're implying here.[/quote]At what point did I make that implication for one size fits all? Last time I checked I was making an argument for the different variations on it.
Reading comprehension. Do it.
dash wrote:Tell us... what exactly do u think a 48trim/0.64 will "grow into" ?
I bet a compressor map and some nerdy math might shed some light on that question.
dash wrote:Oh really ? T3/T4 has ran the gamut approaching 300-600hp. A GT28xx will/has/can NOT service that range ANY better. The same age-old turbo compromises live on.... despite the hype.
Correct. When did this become a point of contention?
dash wrote:Ahah, same "mindset", doing u in. Again... stay away from assumptions. Leave that for the sheep. Exactly the point I've been trying to make.Why do you think all those long "GTxx vs.." pages/threads exist ?Our quickest starion (2.6Lsohc) clubmember drove his car to work everyday. 10.4sec ET pump gas, stock cam!. Old POS T04B @28psi. Lites up tires instantly
Sigh, I totally believe that it does. I was simply musing that, given the rate all other technologies are improving these days, you'd think the impeller design would improve as well. And before we decide that it hasn't, let's ensure we aren't making even more assumptions and consider other factors as to why a fellow like ks13 might be seeing better results from other turbos. Like, for instance, the fact that most of these GT28's are internally gated and the killer T3/T04 setups probably aren't.
