dirt cheap ka-t setup (CRITICS and Suggestions are welcome)
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
I wish they had one for t04e top mount...
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I accidentally ordered the top mount kit for mine.. Everything fits, but I may need to shorten my line...
Romeo_rus
don't shorten it... throw your SR away and get a KA-T!!!
PyR0NiAk
Romeo_rus wrote:don't shorten it... throw your SR away and get a KA-T!!!
Tell you what... We'll go to Jacksonville when my car is finished and we'll see which is truly better. My SR or your BA-T
visser003
Car: 1991 Nissan 240sx Coupe
You guys are ridiculous...
For the oil feed line, go with JGS. They make a line kit specifically for a log manifold + t3/04e.It's like 100$.
Oh, and the KA-T will always make more power with the same turbo setup vs a SR. There is no replacement for displacement.
PyR0NiAk
visser003 wrote:You guys are ridiculous...
Oh really? Because we make jokes about each other's cars while at the same time would do anything we could to help the other one work on it? That's cool..
visser003 wrote:Oh, and the KA-T will always make more power with the same turbo setup vs a SR. There is no replacement for displacement.
Efficiency is a very good replacement for displacement. If all that mattered was displacement, every drag car would have the biggest motor possible.
The highest HP KA I've seen was around 1000. There's a mazworx SR with around 1400.
We can sit and beat this to death all day if you like, but it's a losing battle for both of us. Neither of us will win. SEVERAL THREADS have already proven this. I chose my SR because I like the simplicity of plug and play. Roman likes to do things DIFFERENTLY and on a budget, so he chose the KA. He even had an RB25 swapped S14 that he did himself with nothing but his own tools.
WDRacing
PyR0NiAk wrote:Oh really? Because we make jokes about each other's cars while at the same time would do anything we could to help the other one work on it? That's cool..
That is a damn good post
Hot Roding is as old as the car irself, car guys helping other car guys represents a breed of special individuals. The name and label may change but the people always stay the same. The SR vs the KA is like GM vs Ford by any reasonable comparison. But in the end we're all just car guys pursuing our dreams as we see fit.
As long as our goal is boost we can agree to disagree...and have a damn good time doing so.
WD
Romeo_rus
HAHA.. Chris, don't get offended, you know me... I like giving you crap about your car... AND YOU KNOW THAT I'M JOKING!!! I LIKE YOUR SETUP AND WILL BE FASTER THAN MY KA-T!!! BY THE WAY, CHRIS GIVE ME A CALL!!!
Romeo_rus
I got it running yesterday! runs alright, makes some noise (dust cover for driveshaft rubs against the driveshaft), ans some piping hits body...AEM wideband isn't hooked up and SAFC2 too... (gonna work on it right now)and heat wrap with turbo blanket arrived today, so I'm gonna install it too..
http://www.youtube.com/watch?v=EOw-5g9kKtI
FEW QUESTIONS: THE BOV blows some air all the time... but doesn't blow more with increasing RPM, and blows more when it supposed to. (when car idles and I close the BOV with my hand it starts idling badly- drops RPM)...
Modified by Romeo_rus at 10:10 AM 3/27/2010
Romeo_rus
alright... the car starts and runs...1. AEM WIDEBAND shows that my car idles on 18+ (the downpipe sits in 3 of 5 bolts...) 2. the AFR jumps allover the place from 11 to 18+ when I give it some gas3. the bov blows some air all the time... (sometimes when I plug it - car dies)
PyR0NiAk
Romeo_rus wrote:alright... the car starts and runs...1. AEM WIDEBAND shows that my car idles on 18+ (the downpipe sits in 3 of 5 bolts...) 2. the AFR jumps allover the place from 11 to 18+ when I give it some gas3. the bov blows some air all the time... (sometimes when I plug it - car dies)
Well, you pretty much said everything man, except the wideband was reading 10.0 under boost which is the richest it can read. I still think you have some f***ed up vacuum lines. Your constantly leaking bov might be causing some of these issues as well. Other than that man, it comes down to that emance tune. Hopefully, we can fix some of it with the SAFC...
Romeo_rus
Well... some updates...1. Plugged all hoses (former EGR etc..) now it idles at 17.5 AFR... too leanwhen I add some gas - afr goes to 12-142. the bov blows some air all the time.. when I plug the BOV - wideband shows 18+ AFR and car dies sometimes.3. Unplugged the MAF... idles at 11 afr..
Modified by Romeo_rus at 2:08 PM 3/28/2010
PyR0NiAk
Get a better BOV... I'd start there.
Romeo_rus
Romeo_rus
UPDATES:found and excessive exhaust leak right before wideband 02 sensor...found gas in engine oil...looking for another BOV... (CX Racing BOV opens a little bit on idle vacuum )
Doya
Car: '95 240sx KA-T
Change the oil. Clean your plugs, and if any look different take a pic. Fix the exhaust leak and remove your BOV just for now. I had the same problem. I was idling at like 16-17. It turned out my EGR tube was wide open.
Romeo_rus
Gonna change oil tomorrow..take a look at spark plugs...gonna redo my oil drain...
EGR was removed and the hole was plugged with EGR block off plate
GODCHSR
Car: 1996 Nissan 240sx
Because I am too lazy to look elsewhere... I have the same cast manifold but it won't clear the BMC with the turbo. Did you remedy this problem?
Romeo_rus
1. you have to get a MANUAL brake booster (it is I believe 2'' thinner)2. I had to grind the turbo outlet flange near BMC 1/2 of its thickness to clear the bolt these 2 steps will give you 1/4'' between BMC and turbo/turbo outlet right to fit a heat shield or turbo blanket...
GODCHSR
I think my turbo is too big then because I am not even close.
Thanks
Romeo_rus
this is t3/t04e turbo
PyR0NiAk
Sorry I missed your call yesterday, Roman. My sinuses are all screwed up and I have a constant migraine. I'm hoping it's just allergies and will clear up. As soon as I feel better, I'll give you a call so we can bolt my motor together.
Romeo_rus
Alright I eliminated most of possible problems... still waiting for BOV (greddy RS)... hope it solves the problem, because CXracing one was getting stuck... and probably was leaking vacuum...
Romeo_rus
GOT IT RUNNING GREAT TONIGHT!!! it was crappy BOV leaking boost and vacuum! runs great, will make some adjustments with SAFC2
PyR0NiAk
Romeo_rus wrote:GOT IT RUNNING GREAT TONIGHT!!! it was crappy BOV leaking boost and vacuum! runs great, will make some adjustments with SAFC2
Just have to say, "I told you so." Congrats man.
Feel free to test drive your car my direction, so you can come help me out with my issues today. I get off work around 4:30
WDRacing
That's great man. Feels good when you fix something and everything changes for the better huh?
Congrats buddy, I hope you get to enjoy it for a long while
WD
Romeo_rus
Well... the bov and adjustments made (tighten the bov, so it is now blowing air at boost) made AFR MUCH BETTER under boost 13.4-14.7 moving slightly touching accelerator and 12.7-13.4 WOT.when leave the accelerator the BOV discharges air (it is not recirculated yet) lean - then rich-normal (is it normal?)BUT it still idles at 18+ AFR, I guess I need to adjust it with SAFC2 (adding some fuel) BUT THE CAR F**KING FLIES!!! ALREADY SMOKED 07 MUSTANG GT
Romeo_rus
Can a bad gas cause a rich condition... everything was great until I went for a ride tonight and found that my gas level is low, so I stopped at a gas station (ghetto style, not SHELL OR SOMETHING LIKE THAT) so I cranked the car and it started running pretty lean (15.0 - 15.4) on slight touches of accelerator and run F**CKING RICH on WOT (10.8) ????
PyR0NiAk
Maybe some water in the gas? Going lean when the water goes through, and then rich when it gets the gas back trying to fix it? I'm not sure how much the ecu will adjust fuel...
Romeo_rus
and the answer is YES, probably it was bad fuel... went to refuel at BP and it solved the problem immediately
