Turbon8er wrote:speaking from years of 12v/24v experience... ALWAYS keep Sensitive electronics like that on separate circuits, Power and Grounds. I've seen some weird stuff happen with signal feedback and ground loops, which is probably what you had going on. You may already be aware, but make sure to Ground, directly to Clean metal (wire brush or sandpaper is your best friend here) using a ring terminal, again keeping all Grounds separate.
you would be amazed at some of the ridiculous hack jobs i've had to fix, where people "knew" what they were doing, especially Electrical engineers. They are almost the worst.
Post pics of your setup!!! I'm really interested to see what you got going on!!
PS- i'd move that Positive wire to another source besides the fuel pump... that's a headache waiting to happen. You can grab the main power harness right under the dash going to the column. Just put an inline FUSE!! I don't remember color, but a Multimeter will.
Red- from a relay right from the main power supply.Turbon8er wrote:where do you have each wire going?
Red-
Black-
Gray-
Blue-
their website is horrible.. no links to the product manuals. looks like they haven't left circa-1996 web site development. lame
where did you grab the tach signal? from the ECU wire going to the dash or engine bay? what color is your ecu wire?N/A Q45 wrote:
Black- its own clean ground
Grey- tach signal
Blue- to a relay
Their website is about as unprofessional as how they are with handling a problem-
Lol yeah electronics can be good and bad, cough cough. .. (obd2) cough.Turbon8er wrote:where did you grab the tach signal? from the ECU wire going to the dash or engine bay? what color is your ecu wire?N/A Q45 wrote:
Grey- tach signal
Blue- to a relay
reading about the company and it's history, i think they want positive customer relationships and to produce quality equipment, but i think they are underfunded for serious support, as compared to a company like AEM. It's pretty cool that the guy even mentioned making a specific board for you, but i think you're right... this engine isn't so far different from any other, the product should work.
I'm betting on needing a different tach signal wire. (If it has a manual) Does it specify a square wave for tach?
electronics are the coolest, most frustrating things in the world... kinda like vajay-jays
IThaJ0kaI wrote:A lot of people on the V8 forums say that the gr/bl wire on the ecu doesn't provide a correct tach signal even using a normal tach. Most of the guys have been using the br/yl wire for the coil relays in 4 cyl mode and it working. So maybe if you hook the window switch to one of those wires you may get an accurate signal?
hotshot768;11289 wrote:after trying all other ways, my friend gave me his old msd tach driver to try and it works!. So for everyone wondering, you do have to use a tach adaptor on the VH. The signal wire you use is the ECCS 12 switched for the coil relays on either side of motor( its Brown with yellow stripe wire). you have to cut the wire rather than splice. Also for Autometer gauges when doing this you set the tach to 4cyl. mode. ill make a how to on here with pics this evening.
My next step is to re-wire the pins once I get some time.Turbon8er wrote:a power wire can only flow (to the component) as much current as the smallest restriction allows, ie- the Pin going into the coil. I would almost bet you're not going to gain any actual voltage to the inside of the coil using a 8ga over using, say a 12ga, in this instance. I think the 8ga is overkill with no real benefit. The factory wire is probably 16ga. And if the entire valvecover is insulated from the head by rubber gaskets (including the rubber seated washers under the bolts), then wouldn't it make since that a better ground could be had by going directly to the intake or head?
just some observation.
i wish i could help with the tach wire, but i just haven't messed with it yet. I'm seriously considering buying one of these switches to install myself and find out. Probably next week since almost all of my VC parts are here.
Ya I've got some heatshrink that I was actually going to use but I'm not 100% done with thw wiring and I didn't want to have to cut it off to re-pin the coils which should be fun..Turbon8er wrote:
put the tape down, lol. Use HEATSHRINK. Tape will always come undone with the heat, which is super dangerous on a power wire, the heatshrink will last forever, and it looks much more 'factory finished'.
sorry i'm a critic on that stuff.
re-pinning!?... um, "I don't think so, Tim."N/A Q45 wrote: Ya I've got some heatshrink that I was actually going to use but I'm not 100% done with thw wiring and I didn't want to have to cut it off to re-pin the coils which should be fun..
Good idea either way though good point.
Lol I'm still going to re-pin them, no point in doing something half way I think, if you seen just how bad the wires look on this thing inside you would probably want to re-pin them as well, they're real bad..Turbon8er wrote:re-pinning!?... um, "I don't think so, Tim."N/A Q45 wrote: Ya I've got some heatshrink that I was actually going to use but I'm not 100% done with thw wiring and I didn't want to have to cut it off to re-pin the coils which should be fun..
lol jk ..but seriously. Slow down for a minute. That would be a serious PITA with time better spent on real performance, if that's what you're after. I''m afraid to tell you that it would be pointless, because i have the feeling you're the type to take that as a challenge, lmao. But in all fairness, it would be pointless. And probably break something and have to buy the same thing that was working fine in the first place. You're talking 20 year old plastic under the hood. s***'s brittle dawg. Good grounds and connections, decent gauge wire... you're set. Tidy up, move on.
So the red 8ga wire in your pic is actually a ground? If so, that should help some, so i can see that improving start-up.
My driver's side VC has a leak now, so i ordered OEM VC gaskets from ebay. $43 bucks shipped for both sides (minus the washers). I did some price comparing on several different brands and package inclusions (whether or not it came with the rubber-seated washers) and i think the OEM did pretty good for all these years, so one more round should be fine for a while. The washers are stupid expensive to buy individually, but the Victor reinz set for the G20 or altima (same washer) has 11 showing in the part picture for like $15, so a few sets of those (36, if all yours need replacing) would work, IF they really include 11. I'm gonna look into it.
http://www.ebay.com/itm/NEW-FACTORY-OEM ... 72&vxp=mtr
