I just have the camshafts, no ECU
If I were to get an ECU, it would be the JWT one mated to SR injectors bc my car is turbocharged. So no, i can't rev past 6500 rpm unless I had that ECU remap. You can only rev past the limiter (6500 on mine--i'm surprised yours is 6300, i've brought mine up to 65 plenty of times) if you have an ECU remap that takes out the portion of the computer that dictates the redline (I think...) Plus, such an ECU would take off that bloody speed governor--mine now has more than enough power to go past 120, but it cant..
No, i didn't change the cam sprockets--I don't know if there even are companies that make adjustable cam sprockets for our cars--if anyone knows of any, let us know (links, prices, etc).
I wouldn't use the JWT ecu with just N/A, unless you have at least CAI/H/E/cams/head work...unless you really only want it to remove the rev limiter/speed governor.
