differences between Z32 MAF's
float_6969
I would think around 200hp. It's not THAT much bigger than the CA ....
minutericesentra
Car: 96 Z32, 06 R51
That's it??? you're joking right? I was thinking maybe around 250 or something.
biosehnsucht
the limitation is airflow to voltage output mapping, and since it maps the same as CA or close enough to be swappable w/o retune, it should die off at about the same point..
