http://www.youtube.com/v/HH_TQrtTI5ICar idles a little rough when warming up, idles fine (900rpm) once warmed up, but after that it dies while driving (not in boost) when letting off the gas to shift gears. I can restart and it idles fine but will die again after driving and letting off the gas. This is with or without getting into boost and it’s recirculated anyway. It also studders a bit (like I'm pulsing the throttle while driving). Pulls great at WOT but again dies when letting off gas to shift gears.
S13 ka24det Enthalpy ECU 480cc DW injectors N62 (z32) MAF t3\04 plugs gapped at .031 removed SAFC to diagnose problem (still dies) open exhaust emissions removed Using PLX wideband O2 sensor and outputting narrow band signal to ECU with it This worked fine while NA A\F ratio during die time is 14.5 +/-1
ANY THOUGHTS... leaky injectors, crapped tps sensor, thermostat out, bad ground, anything,?
I'm fairly bummed about this as this is after finally getting it on the ground after 9 months on jack stands… thought I had every thing perfect
Modified by ppctx at 11:00 PM 5/9/2008
