Dies while letting off the gas (not just after boost)
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
ppctx wrote:
Scott at Enthalpy rock (and knows his ****e) Move the MAF away from the turbo and problem solved)
looking at the pic, i knew the maf was too close, and it was already stated that it should be around 12". But you didnt take the advice at first. its alright though i guess.
jbenz
Car: S13 Hatch, S14 Coupe
[QUOTE=DevilMB3017]1) Make sure your recirc'ing your BOV, but everyone will agree with this.[QUOTE]+1
dwaynedman
Car: 1996 240sx 500hp
I have the same problem when letting off the throttle, car dies !! But idles fine when not driving.Is running a AEM map sensor instead of a MAF Better or feasable ?? I have a AEM MAP and AITS to install with my AEM standalone when I can afford injectors. Can the map be used instead of a MAF with A stock ECU ?? You just wire it off of the MAF wires right ?? Some one clue me in on this please.
D
h-eater240
dont let the car out of gear when your coming to a stop or slow down, my **** does the same thing, i just downshift real quick. Do you have a lightweight flywheel? and if so go stock
