I have stalled again lol... Stalled due to ordering a couple more bits of gear..
Couple of things have changed slightly..
Thanks to a mates brilliant suggestion, I will be changing the intercooler pipe routing on the inlet side so it exists the turbo to the passenger side and flows down to the intercooler rather than up and over from the bottom... This means I change the position of the power steering res to behind the strut tower, close to the exhaust, but once the exhaust is wrapped it should be fine as its still +50mm from the exhaust itself..
These bad boys turned up last week..
These are the new HDI clamps that are similar in principal to wiggins clamps, these are used for IC pipe-work, you weld one section to each end, two rubber orings slot into machined lips, slot the female side into the oringed side and clamp up using the well designed clamps, no screws, no pop offs and will handle a stupid amount of pressure..
The drawback is I am unsure how much flex I will get with them, HDI say 2* each way of flex, so I am using silicone joins off the intercooler itself, if I find later on down the track there is enough flex in them, I will add them to the IC itself..
I have ordered this AFM to suit, all theory and data suggests the Z32 will max out on resolution, so had to find another alternative.. One alternative I really wanted to experiment with was a dual AFM setup, but after some discussion about it with a few people this seemed to be the better alternative in the end..
http://www.atomicperformance.c....HTML
And this is my first ever mig job...
Don't care if the welds aren't that nice looking, it will be wrapped in the areas that will be seen and I got good penetration and it doesn't leak... but I am proud of it lol.... another skill I am learning as part of this project.. ^_^
Not much else going on until I get some more gear in... so stay tuned...
Cheers B)
Modified by meminto at 2:18 AM 6/28/2009
Modified by meminto at 2:19 AM 6/28/2009
