do you mean they kept your stock 240 air box? i don't know much about rb25's but that seems a bit odd to keep a restrictive airbox from an NA motor for a turbo motor. hope they do all those repairs for you.grisham101 wrote: ...right underneath my air box, which they said keep because it'll flow better than the mushroom type air filters
No, 250 to the flywheelskylinegrl13 wrote:227? i was reading a lot of stuff that said rb25's put out 250 at the wheels stock, anyone out there know if this is true?
There is no difference between airboxes. My CA18DE and DET cars had the same box and my RB20DE and DET Skylines also the same. The aftermarket should flow better though.Man I get so tired of hearing about shops ripping people off. Doesn't pride in what you do and fair business practice exist anymore? Makes me want to open a shop so people can get honest workskylinegrl13 wrote:
hey all you rb25 guys, give this man some advice!!
the external casing looks identical to a KA trans because they are internally the same transmission but the bolt pattern on the bellhousing is differentgrisham101 wrote:Well, I had another transmission shop look at my car and confirmed that it is a KA transmission. Doug and UP garage swear that a KA transmission CANNOT bolt up to a RB, but I have mine bolted up, and for some reason, other shops say it can be done. Even Wikipedia lists how to do it
http://en.wikibooks.org/wiki/N...25DET
All beware of them. Wish me luck, as I start the legal process to get some of my money back. Too bad Pierce County Sheriff's Department can't do anything about it, since it's a private matter.
Yes, they are interchangable.But normally it's the other way around.Most of the billet RB flywheels I sell go onto KA engines.......grisham101 wrote:re-used my ka flywheel, clutch, and pressure plate setup.
They could've just bought a motor only. They are much cheaper than getting a Motor/Trans. Obviously, they probably found out the reason they are so much cheaper is because people want $1200 for an RB25 transmission. So they just bolted up w/e transmission he has on there, an RB20 I guess. Or an RB20 with KA internals, w/e he thinks it is.blurrbosi wrote:Yah... thats if the rb transmission breaks! What happened to the transmission that came with your motor? Must have been sold for the xtra cake. Seems rreeaallyyy... shistey man. Just hope it doesnt break... I could only imagine what you would have to go through for repair through those people.
