Adding fogs to my wifes '06 and after removing a ton of panels to run the aftermarket wires I notice some connectors.
Are these things pre-wired for fogs?I have one open connector behind each fog hole on the bumper behind the inner splash shield.
I went searching for these when I discovered two connectors next to the mirror and AWD switches on the console.
Am I dreaming to think I can buy a switch and use one of the connectors on the console? Should I continue with the aftermarket install?
Her Murano is currently in pieces in the garage!
Thanks.
