 Fog light install on a 2006 Murano S
dtr508
2006 Murano S
Ocoee Florida
1-29-2007
Hello everyone,
I was looking for info on installing factory fog lights on an S model. I just bought the lights and bezels. Also purchased the 3' wire harness and dash switch. So far the cost is 350.00 . Going to attempt install this weekend. Just looking for any pointers from anyone.
Thanks......
dtr508
2006 Murano S
Ocoee Florida
1-29-2007
 « Re: Fog light install on a 2006 Murano S (dtr508)
Hello Everyone,
Well I did it.... I was able to install the factory fog lights on my
"2006 Murano S" and it took less than 3 hours. I did a google search for the Nissan service manual and was able to buy a PDF version called "2006 NISSAN MURANO WORKSHOP SERVICE/REPAIR MANUAL" for 19.95 . It gave me details on how to install the lights. The website for the manual was called "tradebit.com". I purchased all the parts from "BuyNissanParts.com".
The wire harness for the lights is accessed by removing the inner fender wells. It's about 4 clips and 5 phillip screws.The car comes pre-wired for the fogs. You just have to plug in the quick connect harness from the fog light itself you buy from Nissan.The connectors are located on the opposite side of the inner wells. As soon as you remove the inner well, they will be mounted in plain site. The manual said to remove the bumper to install but it was not needed. The hardest part of the job was removing the multi function light switch "turn signal" .. To remove the switch you have to remove the upper and lower cover just forward of the steering wheel. "4 screws".The lower portion was tough getting back on. The switch itself
has 2 quick release tabs that allow you to remove it. The guys at Nissan said without the new switch,"auto light feature",, the fog lights would not turn on. That was the added bonus I did not plan on. After
everything was buttoned back up I realized that the auto light feature worked.
I don't know why Nissan did not include fog lights in the S model. It wouldn't have bothered me so, but the bumper had 2 cutout holes with ugly black plastic covers. The front of the car always looked like something was missing. Now it looks complete The whole job was right at about 350.00...
The parts I used were:
a - Fog light assembly's L&R
b - Bezels for lights L&R
c - 2 wire harnesses for fog lights
d - Muti function switch "turn Signal"
elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
Thank you very much for the informaiton. Can I turn this into an article for others?
NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328, ask for Justin, say Wes sent you.
dtr508
2006 Murano S
Ocoee Florida
1-29-2007
 « Re: Fog light install on a 2006 Murano S (elwesso)
Hey elwesso,
No problem, Spread the word. I hope it helps. Let me know..
cotufa_azul
Washington DC
3-29-2007
Hello,
Thanks for sharing your experience.
I have wanted to install fog lights on my Murano S as well. Since you already did it, I'd like to ask you couple of questions regarding the fog lights you got from that site:
1. Do the lamps have a clear "white light" or are they "yellowish" type?
2. Do you consider that the "auto-light" switch is actually necessary/required to activate the fog lamps?
3. If so, what is the name of the switch in the site. I cannot manage to find it. The most likely one I have seen is an item called "Auto headlamp ctrl", but it doesn't have illustration. Is that the one that is needed?
I appreciate a lot your help on this. Thanks.
By the way, have you installed white lights in the headlamps?
cotufa_azul
Washington DC
3-29-2007
Hello,
dtr508
2006 Murano S
Ocoee Florida
1-29-2007
 « Re: Fog light install on a 2006 Murano S (cotufa_azul)
Hey,
1- The Fog lights are clear and " bright",. No yellow at all in them. They
are OEM.
2- According to Nissan, the Auto Light switch is necessary P/N#25540-
CB61A... "Switch-ASSM"...65.00. There is some kind of smart controller
that looks for the switch, which allows the fog lights to turn on.
I still have the original head lights on the car. For me they are bright enough especially now, with the addition of the fog lights... If you have any other questions let me know.
I hope this helps.
Modified by dtr508 at 7:01 PM 4/2/2007
jpfaujr
Murano 2007 S
Mankato MN
6-1-2007
Hi,
I am new to this forum so thanks for your time. I have a
2007 Murano S model. I see that you have the 2006 Murano S model
and installed oem factory fog lights and automatic headlights using
the oem stalk switch with " auto headlight feature. " Did you have to
install the light sensor on the dash also to get this working? I ordered
all the parts from my dealership. I am hoping this will work. According
to what you have done with your 06' Murano it worked for you.(auto headlight feature).
Thanks,
Jim
dtr508
2006 Murano S
Ocoee Florida
1-29-2007
 « Re: Fog light install on a 2006 Murano S (jpfaujr)
Hey Jim,
I did not install a light sensor on the dash. I wasn't aware of that being a factor for the auto light feature to function properly. I know that after the install, the lights would be on when I left the switch in the "auto" position, while driving night or day.. I figured it was a daytime driving light option. I know that when I turned the vehicle off, the lights would turn off by themselves after about 1 min.
I don't have another Murano to compare. If anyone has anymore info let us know...
Thanks...........
shinallb
Rome GA
9-1-2007
Hello from a noob owner.
I am interested in adding fog lights to my wife's new 2007 Murano S...do you still have the part numbers for items a, b, and c from your list? Thanks in advance.
TheKrell
Annandale VA
9-23-2007
 « Re: Fog light install on a 2006 Murano S (shinallb)
Quote, originally posted by shinallb »
Don't know about the OP, but here's the parts list that I scanned in from my order:
Item Part Number Part Description Quantity
1 25540CB61A Signal switch 1
2 62256CC20A Fog lamps Bezel Right 1
3 62257CC20A Fog lamps Bezel Left 1
4 26150CB025 Fog lamp assy Right 1
5 26155CB025 Fog lamp assy Left 1
6 24028CAOOA Fog lamp harness 2
(Sorry about the formatting of the above table; can't seem to find how to do preformatted text.)
TheKrell
Annandale VA
9-23-2007
Quote, originally posted by dtr508 »
I did not install a light sensor on the dash. I wasn't aware of that being a factor for the auto light feature to function properly. I know that after the install, the lights would be on when I left the switch in the "auto" position, while driving night or day... I don't have another Murano to compare. If anyone has anymore info let us know.
I don't either, but I have yet to see a Murano with it's fog lights on during the daytime. I think that means we need that sun sensor to function like the other models.
jpfaujr
Murano 2007 S
Mankato MN
6-1-2007
 « Re: Fog light install on a 2006 Murano S (TheKrell)
Hey,
I hooked up the optical sensor on the dash. Ordered
it from my dealership. There is a white plug under the
dash that is taped to some wires. I just untaped it and
brought it up and thru the the dash(removed the tab on
the dash). I also ordered the piece that surrounds the
sensor from the dealership. It works perfectly.
Have a good day
TheKrell
Annandale VA
9-23-2007
 « Re: sun sensor installation
Thanks for that report. Do you have the part #'s? How much did it cost? Can you add the sensor without disassembling the glove box, A/C evaporator, etc?
I see a "Sun Load Sensor" (about $40) and a "Light Sensor Auto Headlamp Ctrl" for 3X that amount. Ouch.
Modified by TheKrell at 2:13 AM 10/15/2007
jpfaujr
Murano 2007 S
Mankato MN
6-1-2007
 « Re: sun sensor installation (TheKrell)
Hello,
Answers to your questions:
1) Your Welcome
2) Just ask the dealer to look it up. It is the optical sensor
for auto headlamp for a SL Model. Yes, it is around $110.00
dollars.
3) No, you do not have to take apart the dash or anything. The sensor
plug is taped to some wires under the driver side. Just crawl under the
driver side and look up and you will see it there. Untape it and fish
it up through the opening on the dash.
Have a good day.
alex_usa
Nissan Murano
Strongsville oh
10-26-2007
Hi, i'm interested in buying fog lights for my 06 Murano from e-bay, they are from "HALO" and i want to install them whitout a swich so when i turn my lights on the fog lights turn on too. Can anybody help with an ideea?
Modified by alex_usa at 12:52 PM 10/27/2007
fastNugly
2007 Murano S
Toronto On
1-9-2008
What site did you use to purchase the below? Some of the part numbers provided dont work on NissanParts.com
Second question, Does anyone know another website that all these things can be purchased at and where to get the optical sensor?
Quote, originally posted by TheKrell »
TheKrell
Annandale VA
9-23-2007
 « Re: Fog light install on a 2006 Murano S (fastNugly)
Quote, originally posted by fastNugly »
It was DirectPartsConnection.
jpfaujr
Murano 2007 S
Mankato MN
6-1-2007
Hi
I purchased all the parts thru my dealership.
I may have paid more but I new who I was
dealing with and they are all OEM parts for
sure.
Have a good day!
sandifordi
2005 murano
yonkers ny
1-25-2008
DO YOU KNOW IF THE 05 S MODEL COMES PREWIRED FOR FOGLIGHTS
sandifordi
2005 murano
yonkers ny
1-25-2008
Thanks a lot for those parts #.They were a great help to me i was able to installed my fog lights on my 05 s model murano.And it came prewired .I can't understand why guys were saying it is not prewired for fog lights.
june0616
2005 Nissan Murano S
Pennsauken NJ
10-29-2008
Hi my name is Larry how u doing .I need your help i was just installed the fog light on my 05 Murano S followed your instruction but some how it's doesn't work i've all the parts# that you've listed wonder if there's an differences between 05 & 06 any advise?
Thank You
Timmbo
Armada/QX56/Murano/EX35 Moderator
'08 Nissan Armada LE & '08 Nissan Altima 3.5 SE
Green Bay WI
11-20-2007
 « Re: Fog light install on a 2006 Murano S (june0616)
Quote, originally posted by june0616 »
Thank You
Welcome to the Murano Forum! Glad to have you as a member of NICOclub!
Sorry to hear that you have reached a "dead end" with your fog light install. I am not sure how it is done, but if you click the link below you can access the service manual for your Murano, maybe this would be of some assistance. Good luck!
http://www.nicoclub.com/FSM/
'08 Nissan Armada LE (Timberline) & '08 Nissan Altima 3.5 SE (Dark Slate)
june0616
Pennsauken NJ
10-29-2008
 « Re: Fog light install on a 2006 Murano S (sandifordi)
Hi just wonder why i can't get my fog light to work please tell me is there anything else i have to do beside connect the wires and replaced the turn signal switch?
Thanx
» Return to Murano Forum
