eh? »
https://forums.nicoclub.com/eh-u12932.html
Wed May 18, 2005 2:00 pm
I swapped the #5 and # 6 coil- no helpI r/r #6 injector with a new one, so spray pattern should be good. I didn't see an clogging in the fuel line.Yesterday and today were warm so it didn't miss at idle except if i revd it. I'd rev it to 2000rpm and let it drop where it missed for ~30 seconds.Now here's another finding. After a hard run shifting to 3rd gear when full warm (80+c) the engine will miss for about ~15 seconds. If i play with the throttle it will stop missing sooner. This has only started today. One i did not mention is for about the first 5 seconds at cold start up it will not miss. Yesterday I changed spark plugs, insulated coils with tape and torqued the head bolts to 100ft/lbs. Today I reinstalled the Blow off valve return hose. So now i have more power after a shift.
Oil consumption is good- none added in 600 miles. Hot compression on al six cylinders was ~140psi, lower but within tolerance of each other. I will do a cold compression test soon. #6 spark plug was black sort of sooty while #1 was whiteish/red.
So my main clues are: First 5 seconds will run on all cylinders (when cold outside)When warm outside, it won't miss until rev'dWill now miss after a high rpm 2-3 shift (due to leaner mixture/more power)No oil consumptionOk compression
I'm at a total loss.
