Damned Short Crank Snout!!!
Jimefam
Yes i Searched.
I pulled off my oil pump to replace it today and find an 8mm crank snout. So now I'm depressed but anyway, I know what needs to be done to fix that but what is involved in getting this fixed. Some people I've talked to make it seem as though I have to rebuild the motor since i'm taking it apart but thats like 2k more. Others say just take the crank have the collar pressed on put everything back together a thats it! $200 that will cost me more or less. Which is it? What will I have to replace to get this fixed I want to drive the damn car already!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Desperation party of one? If your going to take it apart might as well just fix everything else and do a little upgrading. RB means not on the road right away lol.
BoostFab
Car: S13cp, S13fb, S14z
RB = Replace a Boatload.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
if you dont fix it now your going to be paying more in the future. to install the crank collar you going to have to buy main bearings, rod bearings, main studs, oil pump gasket, oil pump if you uprgrading or oem, then you need the crank collar and then take it to a machine shop and have them install it and since its there you mind as well get your crank polished and balanced. so you might be around $400-$900est. its your choice if you want to upgrade the bottom end i would since its already all apart but thats me.
craz4240
Car: 1995 240sx w/rb20det
You could always leave the crank collar for now and stay out of the high revs,get the car running stock first then do the rest.
BoostFab
it's FUD (fear uncertainty doubt), don't you get it ?
just dont past redline and you all will be ok.
Jimefam
Well I already had purchased the n1 oil pump and a complete gasket kit so thats out of the way. I'm looking at another $500 if I dont build the motor and another 2k if I do right? I dont plan and using the car for auto x or anything that will require me to go past redline alot. Mostly drag with this car and i'd be shifting before redline. I think I'll just swap out the bearings and studs and be done with it for now. Thanks
raremotive
Car: 04 Infiniti G35
Jimefam wrote:Yes i Searched.
Let me ask me ask you your goals for this engine... because if you are going to stay under 400 hp and below redline... doing daily/street driving... the short crank oil drive is fine... there are many r32 out there still running with that short shout... and they are being tracked...
The reason it's an issue... more hp.. more crankflex... more revs... more crank flex...even a slight flex is amplified at the ends of the crank... where the drive is...
It's all about the first question... what are you going to do with the damn motor? Also what you are spending for it...I seen cheap builds just replacing the rod studs because stock is too ductile and push up to 500 reliably. I seen people spend much more to get to the same...
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
FYI, if you want to do a crank collar, I have a perfect RB25DET crank with a JUN crank collar already installed.
I'm going RB30 and no longer need a 25 crank.
[email protected] if you're insterested.
Jimefam
My goals are between 300whp and 350 whatever I can efficiently get out of the turbo. And as i stated before I want the car mostly for drag it will be a second car I as already have a DD and will use it maybe 350 to 500 miles a month. I dont think I will be going near redline to much.
240z4u
Car: '95 Nissan 240SX
I pulled my crank, had the snout welded and machined and slapped it back in. That was over 20k miles ago.
Evan
Phat_Optimo
Car: 93 S13 SE
Have it welded then machined. Its a better fix than the collar IMO.
BoostFab
Phat_Optimo wrote:Have it welded then machined. Its a better fix than the collar IMO.
as i have said it before and will say it again. yes permanent collar is better than a bolt on (affix) collar. get it welded and machine...it usually cost less with the welded route. and screw ordering through Australia....who knows how long it takes. Any automotive machine shop in town can do this, it's their day job.
RB24D
Car: 1996 rb25det 240
won't the heat generated from welding the crank change the tensile strength of the crank?? Mabye a noob question but I think it's a good one none the less.
Phat_Optimo
Car: 93 S13 SE
RB24D wrote:won't the heat generated from welding the crank change the tensile strength of the crank?? Mabye a noob question but I think it's a good one none the less.
Nah the heat is not great enough to damage it. Crank weldings been going on for many years. I actually used to work in that type of business.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
I had my crank snout machined, a new collar made, welded together, and micro-polished for a crisp c-note. While my crank was out, I opted for new main and rod bearings. I spent $200 on bearings.
I also installed an N1 pump. I did not bother to replace my bolts. I also used Permatex liquid sealant on the oil pump, along with Permatex assembly lube.
If your motor is in good / moderate condition (which it appears to be) you should be golden.
I considered tanking my block / blue-printing my engine, but I opted not to, since I did not want a $10,000 motor on a stand.. I wanted to freaking use it!
RB24D
Ok just wandering I may go that route then As my engine is currently at the machine shop for the same issue .But I opted to go the 10k route
redtop240
Car: 92 240 RB20 Coupe
I have a serious newbie question, dont hate...what is a short crank snout. I am just wondering as to thats new to me.
meet07
Car: 89 180sx rb25det
I have the write-up but cant transfer it to the internet for you to see. If you throw me ur e-mail I can send it that way.
rotorimp
Car: 02 Xterra, 60 IH Metro
So I had this same problem. I TIG welded my crank while it was installed. Since oil pump engagement was what I was after I took my time/filed it flat till I got perfect contact. I have around a 1000 miles on the car and so far so good.
zerothread?id=243742
BoostFab
rotorimp wrote:So I had this same problem. I TIG welded my crank while it was installed. Since oil pump engagement was what I was after I took my time/filed it flat till I got perfect contact. I have around a 1000 miles on the car and so far so good.
not sure how much your method will throw off balance.
i might give it a shot, but probably fill it all around the snout for better balanced.
rotorimp
Might be a gram off-- but since it is closer to the center of the crank I don't think it will matter.
