thanks forthe input man. Much appreciated.Ubernoober wrote:Stock SR swap: The cheapest and lowest power solution. The problem is the potential hack-job done during install.
SR swap + major upgrades: Unless you rebuild the lower end this would be the midpriced option. If you rebuild it is right up there with the KA if not more. The problem is the unknown lower end. 300whp is taking a big chance on the condition of the lower end.
KA-T: Most expensive due to the need to delve into the bottom end to guarantee any kind of long term reliability at 300whp. But the easiest by far since you can keep all the original bits. Not only that, spare blocks are just a junkyard away, and parts are right there for you at the local parts store.
Since you don't give a dollar amount I can't really add much else. If $2500 is your build limit you won't get 300whp reliably in either engine. I am sure others will disagree, but only those with a 300whp SR or KAT have any legs to stand on.
I think the Motorset would be the best Idea too now that you say something.... although I cant imagine getting 300whp to be that hard.240DRFT wrote:if i were you and was going to get an sr20 i'd get a motorset over a clip. are you gonna do the swap yourself?
ubernoober what r u talking about the lower end? rods/pistons? the sr's stock rods/pistons could hold 300hp...
i think you'll need more than BPU's to get 300hp.
if i were you i'd get the sr20. you can swap it and have a turbo motor to work on. the ka your gonna have to peice together parts and its gonna take longer.
Isn't it 205 in the stock redtopIWannaS15 wrote:Youre right, this has been beating to death.Its all up to you.
My advice: If youve never worked on an engine before, stick with the KA. They have just as much potential as the SR. 300whp is attainable with stock internals. And its already in the car. If you find a high mileage 240, you can swap in a low mile motor for well under $500.No waiting for your motor to come in on a boat. No $2000-3000 investment just to get the stock 180?whp SR in the car.
so 10psi can be safely driven daily?98s14inaz wrote:Stock internals will handle up to 12psi with the correct fuel and timing managment. Assuming the engine was well taken car of.
Thank you for taking the time to type all that out!Nismo_Freak wrote:Sigh, not another one
Ok, if you want a reliable and cheap setup then I suggest a low boost KA-T. There is reasoning behind this.
1. Spare motor should be reworked and in 100% perfect running order. You can put pistons n stuff in it if you want but I think the stock stuff is fine for holding 7-10 psi on a reasonable turbo. I suggest you replace most seals (mains F&R, etc.) to prevent small leaks. You should give the motor a complete tune-up in the fuel and ignition side of things. Verify the compression is good and leakdown is within reason. It would be in your best interest to replace timing chain components as well. This will give you a good base to turbocharge.
2. Availability of the KA engine itself is alot higher than the SR. It also operates on a simplified valvetrain, and a relatively easy setup. If the motor blows you can always revert back to another KA. Even ran in N/a trim... which is still possible but it won't run very well with the turbo tune.
3. No wiring mess, it eliminates associated problems that I've seen on at least 3 cars in my local area alone.
4. Don't get concerned with money. Once you start cutting corners on any project you create problems. Be sure you can afford it before you jump in with both feet.
I still prefer the SR engine, but I don't suggest it for you given your criteria.
Yeah no problem. Believe me... it's nice to have the ability to build a project on the side. That's one MAJOR benefit to the KA-T is that you can start the project with little money and work at your own pace. Make sure everything is right before you drop the motor in.Bobby12many wrote:Thank you for taking the time to type all that out!
You made some very clear points that rang in my head for a while.
I think I am going to start piecing together my turbo kit for low-boost KA, and in the meantime replace all of my worn suspension parts.
Once all of the Turbo parts are here and installed, I can look about building a stout little KA block that can handle a tad more boost.
Thanks again for the input!
The Evo is a 2003 with Wing and SUnroof. 15kmi, Blue By You color, IMMACULATE condition (not a flaw on it!)Eikon wrote:I think you should go RB20det. Fits your price range.. generally same power potential as SR/KA-t, etc... Best sound by far.
The real reason I am posting is:tell me about the EVO you are selling. I have a friend here in Green Bay who is looking for one. Is it still for sale? How many miles? color, condition, mods, price, etc...???
Thanks
Plug and play. It runs a little rich but that is peace of mind if you have a boost spike and or some other issue. You are less likely to detonate.ILikeMy240sx wrote:Dont you still need SAFC to fine tune JWT ECU? Or is the JWT ECU just plug and play
