Its almost summertime again which means hitting up more drift events, start off the drift season right with products from TrackWell Performance!!!
Give your right hand a brake with a hydraulic hand brake conversion kit from D2 Racing only $250!
Also make sure your sprung right with coilovers from D2 and Stance!!
D2 ONLY $950The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts*. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
Call or Email for Pricing on Stance.GR+ is our main flagship line of coilovers. Oversize diameter shocks allow large pistons for ultimate performance and response. 15-way adjustable damping allows the driver to tune the shocks for any conditions and handling characteristics. With huge range of adjustment that can be felt and seen, GR+ offers serious performance for all levels of drivers. GR+ coilovers are built with highest quality materials and tolerances to ensure durability and performance.
GR+ Performance Suspension System Features:
* Adjustment Knob 15-Way Damping Adjustable * Upper Pillowball Bearing Adjustable Camber Uppermount * Upper Pillowball Bearing Pillowball Uppermount * Spring Cold Wound Linear Spring * Monotube Inverted Monotube Shocks * Boot Dustboot * Collar Aluminum Collars & Upper Mounts * Bracket Height Adjustable Lower Bracket
Coupon code: nicoclubIf you have any questions contact Clay 912.337.1942 or
[email protected]
