CX Racing ebay Turbo Kit - What can you tell me about it?
liteemup39496
Car: '89 s13 Coupe ka24et - 400whp w/ac eta 2014
'91 s13 Hatch vh45de - the track bunny
'95 a32 Maxima vq30de - Daily pretty and quick
LOL watch out WD is gonna pop
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Meh don't worry about him. He fights like a Norweigan. I seen Russell Crowe kick his a** before!
HGOTBOOST
Car: Camry
I am skeptical about the kit waiting how did yours work out because i will be starting my project 240sx next month or so...I was thinking of buying the same turbo kit because of tight budget just wondering if its actually going to work.I am not throwing my money down the rat hole.
liteemup39496
well right now my 2 main issues are the fact i have a bad rad leak and thats getting replaced today with a s14 rad. which is slightly thicker then s13.
also clutch should be going in next week. by that time if all goes the way i want i will have the ecu chipped and a base tune with LC-1 wideband and fine tuned with safc and dsm 450 injectors. so i can ditch the fmu
really depends on the weather,
HGOTBOOST
Car: Camry
liteemup39496 wrote:well right now my 2 main issues are the fact i have a bad rad leak and thats getting replaced today with a s14 rad. which is slightly thicker then s13.
If everything goes well with your kit and car is running fine @ 7-8PSI let me know because what i was thinking of an S13 was
-CX Racing Turbo kit http://www.cxracing.com/mm5/me...=TOKT
-370cc Injectors
-Tuned ECU
I want around 250-280hp
liteemup39496
yes thats pretty much my goal also of 250whp and im satiated.
liteemup39496
ok so today was beautiful out and i decided to take advantage of that and pull the manifold replace all the bs hardware and seal everythign up nice n tight. also while i had everything out i swapped out plugs for some bk6re's gapped at .030
here are requested pics of manifold
sorry in advance my girl played with camera settings and pictures are in black and white
car sounds really good and spools fairly quick. ordering ordering LC-1 w/db gauge tomorrow. since im only 25 min away im going to go pick up the ostrich v2 at Xenocron. however i think i may sell my 450cc injectors for some rx7 injectors so i dont have to fudge with wiring.
idamaster
Car: 92' 240sx, 98' 328i
I thought their cheap turbos were s*** but a friend of mine has been running two of them without failure at 16psi.
NiceLyphe
Car: 1992 Nissan 240sx
Hmm this looks pretty good for a start/project car at low boost, maybe ill save up for it.
liteemup39496
Well here is an update i think my waste gate is Fubar'ed cause i saw a serious overboost issue.
its hitting 16psi which it never did before. so needless to say i dont let it go to full boost, really i dont allow it to go above 3-4psi. funny thing is the wastegate opens at 5-6psi
i am ordering an EMUSA wg, and installing the lowest spring which is listed as 4psi.
will prolly take a week or 2 to gather the funds for it. while its out i may wrap the manifold and i plan to have wg rerouted into DP to quiet things down. also most of my tuning parts are here so i will be converting to Blow thru setup as well.
240sxRturbo
Car: 1991 240sx lx 10:1 compresion
i bought the cx kit for my kae and well im haveing really bad idel problems it will idel pretty well at a stand still but if i drive it and come up to a stop sign or light it will 9 times out of 10 just die can anyone help me
WDRacing
Are you running a BOV? If so, is it vented to the atmosphere? If so, thats the reason.
WD
240sxRturbo
well i havent had a bov on for a while and i finnaly put it on the other day and it helped out alot and yes its vented to atmosphere but i am still seeing idel surge and another thing today i noticed that when i drive my car it throws out white smoke never did that before untill it was turboed any ideas
liteemup39496
well if your still seeing surge you need to loosen to the adjustment screw on the bov.
went thru this recently myself was kind of unsure how much i should loosen but a friend with a like kit told me keep loosening and then checking that it functions properly without surge till its right.
as for white smoke are you running an FMU? good chance your spitting out alot of unburnt fuel. also depening on the smell of the smoke you have a popped headgasket. if it smells sweets like antifreeze your HG is toast
my idle N/A always sucked and for some reason once i boosted it idles perfect i would make sure all your vaccum lines are sealed with no cracks or damage
WDRacing
The BOV usually causes the stall problem. Low boost surge isn't really a problem. If you're running more then 10 psi I'd get a BOV. Just my .02 for BOV's.
White smoke is burning water, Blue smoke is burning oil and Black smoke is running really rich.
240sxRturbo
ok well ill check the smoke today, and my car would stall even when i didnt have the bov on but it did get better when i put it on so i willl loosen up the screw and see if its better ..... ill keep u guys posted
240sxRturbo
ok so i smelled the smoke and it just smells like smoke lol but i removed my muffler and had a dark coolerd liquid come out a little it sprayed me when it got reved up wasnt oil thou i put a piece of paper behind the exhaust and reved it up and dark black wet spots ended up on it my buddie says maybe unburnt fuel but its deffinatly not oil or coolant
Ryencool
it could be unburnt fuel because your not running an ECU or tunning. It could be oil since your oil return on your turbo is hooked up to your valve cover and not the oil pan.
This guy has a post right above this, and you can see why hes getting white smoke.
Just makingsure the responses stay in one thread.
WDRacing
Good lookin out
240sxRturbo
thanks guys i will continue to talk about it in ka-t issues
liteemup39496
so moved into a new house with 2 car garage and this is where i currently am:
pulled motor 21 years of oil, grease and grime
6 hours + 1gal purple power degreaser+ old oral-b toothbrush = its white again after 20 years
1.5 cans rust-oleum 2x ultracover primer. this stuff rocks
2 cans rust-oleum 500f high temp engine paint gloss black. 1000x improvement
total worktime took me about 8 or so hours across this past weekend
getting wideband bung welded in and WG dumptube rerouted into exhaust and lots of exhaust wrap for the kit,
then wiring up my dsm 460's and installing my xtd stg3 clutch
Has anyone else bought an ebay turbo kit? If so, post up - I'd like to include you guys in a series we're working on in the near future.
Thanks!
WDRacing
I've been doing my best to dissuade people from going the ebay route as of late. Far more failures than success stories by quite the margin.
