the stall converter helps build up the RPMs when launching it right? because something like that needs to be done with the CVT altimas and take out the restrictions...... so do any 6 speed manual 3.5se people have time slips?08Coupe wrote:Most newer cars are faster with automatics..Not sure about CVT's but take a regular automatic, add a high stall converter then point and shoot..lol Now the stick will always rule the full track, being able to downshift, pick perfect gearing ect.Wait to a M6 gets a 1/4 slip~ the 60 ft., 1/8 mile et and mph comparison will answer your question.
I agree 101%. Most manual transmission drivetrains have a power loss of about 15% - 18%. Compare that with that most automatic transmission drivetrains (at least the ones that use a viscous fluid) have anywhere from 25% - 35% power loss. Given the same engine power output, the maunal will win most every time.adidas2go wrote:I dont think thats true, I would say only a small percentage. A few of the european transmissions with the DSG and SMG, but not very many automatics are faster than manuals
Those numbers always change from place to place. lol.leifab wrote:good rules: of thumb:
100lbs of static mass = .1 off 1/4 mile1lb of rotating mass = 7lbs of static mass- 1lb of rotating mass = approx .5 whp
btw i was watching your video of the in-car view, and that screeching sound between shifts is not good. my car does it sometimes because the throttle plate is left open a little and the revs jump in btwn shifts. i think its the clutch...how many miles do you have on your car, and do you beat on it alot?08altima35 wrote:put a stop watch on this run the best you can. i'm pretty sure i ran a 9.1 on this one.http://youtube.com/watch?v=a7a_a5Wmfx0
i also have another vid of me getting 0 - 60 in 5.2 and the tires spun a bit at launch.
reason for race cars that are auto is to run consistent times. just press gas and go and you should be able to hit roughly the same numbers each time. where as manual, you wouldnt hit the same numbers all the time and you would have to judge when to shift or when to let off the gas...Hussain wrote:no i have the base 3.5se CVT. and about automatic vs stick shift i did hear from several people that auto is faster. STOCK vs STOCK manual wins BUT after a couple modifications to the automatic transmission (not hp or anything, just the transmission) and automatic is faster. this is one reason why many professional race cars are actually automatic. i don't know the exact details but i did hear that automatics can be faster with a torque converter and maybe some other stuff.
To add to that. Auto with Paddle shift or straight cut gears are used more often on the higher end super car class races because its more accurate and they shift faster than Mr. Andretti himselfniztec wrote:reason for race cars that are auto is to run consistent times. just press gas and go and you should be able to hit roughly the same numbers each time. where as manual, you wouldnt hit the same numbers all the time and you would have to judge when to shift or when to let off the gas...
i know for bracket racing, auto is preferred...
lol, that was when the clutch had about 1800 miles on it man. don't worry! that sound isn't grinding bro.One Crazy Max wrote:
good question. i'm guessing the only way to get rid of the 90mph slow down is to get a ECU reflash or something? does anyone know of any way to get rid of 90 mph slow down? and maybe a way to allow it to build up revs.... i heard CVT doesn't have a torque converter like regular automatic but i don't know if thats true or not.chamade wrote:Will there be a way to remove the 90mph slowdown?What about a "racier" torque converter?
no no no...you are misunderstanding me. what you are defining is chirping tires, what happened in the video was not that at all. trust me if he wouldve chirped 2nd the tires wouldve been spinning a little and then caught up, and it happened 3 times in that vid if im not mistaken, and ive never chirped tires that loud going into 4th. i have the 6MT, and i know the sounds that it makes. that screeching noise happens when your foot is still on the gas in between shifts leaving the engine to rev up a little and causing it to spin too fast before you engage in the next gear which then causes the screeching noise because the clutch has to catch up to the flywheel.adidas2go wrote:
hahaha
That "screeching" sound is only him "catching" 2nd gear. Happens when the engine is spinning faster than the transmission when you drop it into the next gear and tires catch up with the actual speed. It actually is a direct reflection of a good shift
but before you unbolted the catback you were also slower in time....so i come to the conclusion that CVT FTL, and 6MT FTWHussain wrote:lol looking at my time slips, most of my runs were in the left lane (when i did NOT unbolt my muffler) and that's the lane that the 1/8 mile sensors arn't working lol i only found 1 time slip of me in the right lane and it just happens to be my worrst one! where i ran a 14.5 lol my 1/8 mile in that run was 9.474 @ 78.021 mph..... so you were about 1 mph faster (1.019 to be exact) and that was on my slower run.... so i guess it's safe to say they do the same speed in the 1/8 mile but as for the time, i think stick might be like .1 secs quicker in the 1/8 mile if raced correctly.
when i unbolted the cat-back (when i did a 13.9 in the 1/4 mile) i did 8.992 @ 80.289 mph in the 1/8 mile.
just listened to the video 3 times, still don't here anything but the tires spinning at the launch , tires spinning into second, and what sounds like a hard shift into third. Pretty sure he never goes into 4th, but it could just be my sound sucksOne Crazy Max wrote:
no no no...you are misunderstanding me. what you are defining is chirping tires, what happened in the video was not that at all. trust me if he would've chirped 2nd the tires wouldve been spinning a little and then caught up, and it happened 3 times in that vid if im not mistaken, and ive never chirped tires that loud going into 4th. i have the 6MT, and i know the sounds that it makes. that screeching noise happens when your foot is still on the gas in between shifts leaving the engine to rev up a little and causing it to spin too fast before you engage in the next gear which then causes the screeching noise because the clutch has to catch up to the flywheel.
adidas im not sure if youve driven the new alti 6MT hard yet but thats what happens when you dont shift properly. it doesnt effect time, but it causes damage to the clutch!
