boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Tue Aug 26, 2003 11:35 am
Quote »Excellent, when i financially can, i plan to buy a CA motorset, and get the SDS system going, with your help boost_boy. What kind of initial power can i expect, with nothing more than SDS, FMIC and exhaust? That will be stage 1 of my install. Then later i'll go nuts with forged parts and injectors and turbos and shred some rubber.[/quote] Lets just say we take the stock T25 to it's maximum efficiency band= around or about 230-260 hp and 260 is pushing it. I'm here to help; just holla when you're ready.Quote »so basically i can get that whole system with the knock sensor, oxygen sensor, maf and all that other stuff for under 1300? is that shipped or shipping is extra?[/quote] Shipping would be about $25.00. Quote »and when you make the harness are all the wires tagged or do they have any kinds of markings on em?[/quote] All wires and connectors are tagged to plug and play. These guys really are very helpful, indeed.Quote »could you list every feature that comes with the $1273 "loaded" system you mentioned?[/quote] With my discount you'll get knock sensing, 3 bar map sensor, fuel pump relay, something else too I can't remember. Quote »with a motorset(considering engine and transmission are in good shape with belts/clutch/etc refreshed), sds system, fmic, and an exhaust and all necessary piping would i be ready to roll?[/quote] Yes!Quote »any instructions included?[/quote] If you're referring to the SDS, then the answer is yes.
Dee
