I can't tell you what the S-AFC does exactly -> but any system that uses the MAF signal will recognize boost indirectly
rant:nono
Air flow and air density is 2 different things.MAF = Mass Air FlowMAP = Manifold Absolute Pressure
MAF sensor CANNOT see boost. You run S-AFC to compensate extra boost you running, by fooling your ECU you have more air coming in ( determine by RPM , and your boost of course ) That's is why is hard to tune.
Tuning, more/less fuel in S-AFC, faster/slower rpm, faster/slower spooling, more/less air flow, wrong fuel ratio... againTuning, more/less fuel in S-AFC, faster/slower rpm, faster/slower spooling, more/less air flow, wrong fuel ratio... again.. and it keep going. To change your stock MAF to MAP is difficult too because you have to put temperature, huminity and Volumetric Efficiency into count. ( MAP don't do that )
There are cons and pros running MAF or MAP. I can't tell you which one to choose but I will stick with my stock MAF
Not sure if 370cc will "ok" for you 7psi setup. If I were you, I will get a FMU to raise fuel pressure while in boost. You never know you will need more fuel if you hit spike to 12psi.
In your turbo list, you forgot:WastegateBoost ControllerTurbo Timer (unless you can wait 2 minutes sitting inside your car after a hard driving, not very neccessary if you have money for new bigger turbo in next few years)Blow off valve ? hmm.. for MAF , you wanna try By-pass ValveStarion Intercooler ? woo... big and expensive. To run 7psi ?? I think is overwhelming.
Running KA-turbo is a wise choice.
