Custom Plenums (intake manifolds) for CA's
DeJi
Car: 1991 200sx s13
from what I've read, it's 60mm.. I wouldn't mind putting an RB25 TB on there, but there aren't that many of them on ebay. There are lots and lots of "Q45 BIG 90MM" throttlebodies however.. but that's a bit big.. unless 90mm is the outside diameter? Which would make the throttleplate around 70-75mm?
ISL33P
Car: VH45DETT powered
the internal diametre is actually 83mm the outside is 90mm. depends on your setup, the Q45 might be suitable
DeJi
Car: 1991 200sx s13
I'm going for about 400bhp (got a garrett GT2871R on atm and not planning on going any larger than that really). A Q45 throttlebody sounds way to large for me
ISL33P
good point. just try to get your hands on something around the 60mm mark and it should be fine
DeJi
Car: 1991 200sx s13
I've decided to go for a KA throttlebody, it's 60mm and it has the same hole pattern as the stock CA one, but probably with a larger centre hole The only problem with it though is that it seems like the throttle cable runs on the other side of the plenum (towards the head). But it should be possible to route the cable on the "wrong" side right?I have to make my own bracket for the cable right?Would be relatively easy to do if there was two nuts welded to the plenum, so you could just make up a bracket that bolts to those two nuts. Otherwise I'll have to find someone with a TIG-welder. Not that that matters for me, since I know a guy who owns one, but it's just an idea.
float_6969
Simply flip the TB over and don't use the coolant ports. That is exactly what I did and it works fine.
Edit: are you using a KA-E or KA-DE TB?
ISL33P
spot on....thanks Float
DeJi
Car: 1991 200sx s13
I'm not using anything yet, haven't bought it.. I did read that the KA-E is larger than the DE? Or is it the other way around? And how big is the difference?Which cars have the KA-E engine?
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
1990 Nissan 240sx.
shogun!
Car: Nissan 200SX S13
>>ISL33PSent you another e-mailcheersTim
shogun!
This is the TB I will usehttp://www.garaget.org/mypage/...19421
Modified by shogun! at 7:42 PM 1/28/2007
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
I haven't read all 8 pages but is there any way to get the plenum swapped 180 degree's to fit a FWD?
AWDB12wagon
ttt
niscort
just get one for a FWD... this is a CPC btw
AWDB12wagon
What is cpc's website?
shogun!
I have sent you a new e-mail.Could you please have a look at it.cheers'
ISL33P wrote:shogun! - thank you for the email and i have just replied. hopefully we can sort something out.
tyrannix $800 seems fair, i am happy with that.
Ariel
ISL33P
niscort, thanks for the photo.
shogun! email replied to.
bren
Ariel,
I bought my CA plenum from you last year. After fitting it to the car and finding out the output range from the TPS switch was limited and the return spring wasnt strong enough to hold the throttle plate shut when coming off the throttle the plenum then split the first time the car ran full boost.
I sent the plenum back to you and after refusing to refund me you said youd send out a replacement.
I havent had one despite the original being sent back in March.
Where is my plenum?
Bren
ISL33P
as i mentioned last week, the plenum has been machined and it will be ready for posting on monday. i am sure you could have emailed like every other time. very unprofessional of a businessman like yourself
email me your address if you still remember how to use it
float_6969
I just emailed the both of you about this. Please check your emails and let me know what's up.
Ryan
float_6969
Ariel. I need you to contact me ASAP. I've emailed you. Thank you.
ISL33P
Ryan - all done a few days ago, just waiting on a repsonse.
Ariel
float_6969
I'm glad we got all of this sorted out. One of these days I'm gonna be rocking this manifold....
shogun!
http://www.garaget.org/mypage/...47137
Modified by shogun! at 7:36 PM 1/28/2007
hsoj_v
Car: Nissan 200sx XE (Silvia S12)
Wow, very nice.How much again?
ISL33P
thanks Shogun.
PS - when is that site going to be available in english ?
hsoj_v - $AU800 + delivery approx $AU100, approx $US675 to your door.
That was one of 7 i have just sent to Sweden as a group buy. If you guys could get the same numbers, you would be looking at betweem $US550-$US600 delivered to your door.
Let me know how many people are interested.
shogun!
ISL33P wrote:thanks Shogun.
Hi. I do not know if they ever will make an english version of that site. It would be good in my opinion.
I will post some new pictures as soon as the plenum has been mounted on the engine.
shogun!
ISL33P
Thanks Tim, glad you are impressed.
Ariel
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
manifold is looking nice, is this the design that was flow tested?
also how do you like that phone? ive had mine for a few months now and so far its great few little things im disappointed in it, ill probably never buy another phone that expensive again...
